Oil Filters Stock Vs Aftermarket
Geo
So be ordering some Oil and Filters over the weekend, and was wondering about the Filtration on the filters.
Now i used to use the stock, then i moved onto the Lexus V8 filter, as these are bigger, holds more oil, and has better internals. see links below
Toyota/ Lexus Oil Filters - Stock 08922-02011 vs Lexus V8 90915-20004
Size comparison on filters
Now the Lexus filter 90915-20004 is now been superceded with part number 90915-YZZJ4 which i've not yet tried. And should in theory be the same size as the old filter, i'll report back on this once i install my new one.
Looking for peoples thoughts on the Oil Filters folks? what you have used, price, size etc etc.
Thanks
I have a K&N one on mine for the main reason that there's a nut attached to the end which makes it really easy to get off. Plus it's a reputable company. Pretty cheap off eBay too :)
http://www.ebay.co.uk/itm/K-N-KN-OIL-FILTER-fits-TOYOTA-SUPRA-3-0-1986-1998-HP-1002-/130600075987?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e685f02d3#ht_1309wt_1303
:yeahthat:
I really enjoy the manliness of hammering a screwdriver through something that annoys me.
But also that! :D
K&N nut on the end sounds like a brilliant and simple idea but I really enjoy the manliness of hammering a screwdriver through something that annoys me.:D
The nut is a great idea if you know how to fit an oil filter properly. The 1.4 vw/seat engine has this & nearly every one i get in for a service it has been way over tightened & just brakes the bolt of anyway. This leading to alot of swearing & name calling lol. The last one i had i had to put a oil filter vice grip type with a long bar attached to remove it, this was after snapping 2 filter straps.
