Marco79 Posted September 19, 2012 Share Posted September 19, 2012 Ive got a built na/t engine now as a starter engine (for the drag build) which has a realistic limit of 600bhp, now my question is I have a precision T67 turbo and 1000cc injectors for my GTE build, is it possible to run the turbo at a low enough psi so I can use this one on both engines and would it be possible to control the injectors with a syvecs so I can use these aswell without drowning the engine? Or am i destined to find a T61 and 650cc injectors? Appreciate any help with this Quote Link to comment Share on other sites More sharing options...
Alex Posted September 19, 2012 Share Posted September 19, 2012 Yes the Syvecs can control the injectors... Are you running stock NA compression? It's the compression that's limiting your boost. Quote Link to comment Share on other sites More sharing options...
Marco79 Posted September 19, 2012 Author Share Posted September 19, 2012 Yes the Syvecs can control the injectors... Are you running stock NA compression? It's the compression that's limiting your boost. Ok cool thanks mate will be running tt compression, just wondering if this is poss as saves me buying another turbo and injector set Quote Link to comment Share on other sites More sharing options...
Alex Posted September 19, 2012 Share Posted September 19, 2012 Oh I get you now - yes to both. You can run the T67 at probably 7-8psi...but if the Syvecs is mapped to it the mapper will decide the limit. Quote Link to comment Share on other sites More sharing options...
Marco79 Posted September 19, 2012 Author Share Posted September 19, 2012 Oh I get you now - yes to both. You can run the T67 at probably 7-8psi...but if the Syvecs is mapped to it the mapper will decide the limit. That's great thanks mate, yes it will all get mapped to suit and Ryan will be earmarked for that job! All I need now then is a T4 manifold for the GE and I'm off Quote Link to comment Share on other sites More sharing options...
