l.chris97 Posted September 19, 2012 Share Posted September 19, 2012 Guys Just finished up fitting my fmic tonight..everything went pretty as expected..but when i fitting the new small expansion bottle in place between the battery and wing..the lh headlight will not fit now as the expansion bottle is fouling of the outter bulb and both headlight studs...has anyone come across this problem before and have an alternative mounting place for the bottle or know an easy fix for this problem..any help would be great. Chris. Quote Link to comment Share on other sites More sharing options...
Westy Posted September 19, 2012 Share Posted September 19, 2012 Mine slotted straight in without issue, but you could always mount it on the opposing side as long as you aren't running the stock airbox!? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted September 19, 2012 Share Posted September 19, 2012 I just mounted mine slightly further back from the stock position, just held with 1 bolt rather than two, i couldnt mount mine behind the light either as my battary was too big Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 19, 2012 Share Posted September 19, 2012 What are these tanks for as I dont think I have one Quote Link to comment Share on other sites More sharing options...
David P Posted September 19, 2012 Share Posted September 19, 2012 The N/A expansion bottle is smaller and a perfect fit next to the battery. Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 Seems my battery is also to big as to even get the expansion bottle in place is a struggle even without the light in place. Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 I just mounted mine slightly further back from the stock position, just held with 1 bolt rather than two, i couldnt mount mine behind the light either as my battary was too big Did you use the mounting plate supplied mate an jus bolt it in place threw a hole on the cross member or front panel? Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 What are these tanks for as I dont think I have one U must have one mate...its an overflow bottle to allow for the expansion of the engine cooling water...if you follow the little pipe beside your rad cap it will go to your expansion bottle. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 19, 2012 Share Posted September 19, 2012 Are you talking about the rad overflow bottle? I thought you meant an overflow tank for the fmic Quote Link to comment Share on other sites More sharing options...
safcdixon Posted September 19, 2012 Share Posted September 19, 2012 Did you use the mounting plate supplied mate an jus bolt it in place threw a hole on the cross member or front panel? Just the screw hole did it up tight as possible, as it doesnt hold much anyway one bolt is enough mines been there for nearly two year now Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 Just the screw hole did it up tight as possible, as it doesnt hold much anyway one bolt is enough mines been there for nearly two year now Yours must be diff that mine mine mounts on a flat plate that slides up the side of the bottle...does your have fixing holes on the bottle itself. Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 Are you talking about the rad overflow bottle? I thought you meant an overflow tank for the fmic Yeah d rad ovrflow...when you fit a fmic the stock bottle has to be removed Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 19, 2012 Share Posted September 19, 2012 Yeah d rad ovrflow...when you fit a fmic the stock bottle has to be removed Ok. Thats probably why I dont have one and have just the pipe and cap hanging loose Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 Ok. Thats probably why I dont have one and have just the pipe and cap hanging loose Maybe best getting a bottle mate as the system can draw back from the bottle when needed also. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 19, 2012 Share Posted September 19, 2012 Just bought one from a member mate Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted September 19, 2012 Author Share Posted September 19, 2012 Just bought one from a member mate If you run into the same prob as i did...let me know were u mount it mate. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 19, 2012 Share Posted September 19, 2012 If you run into the same prob as i did...let me know were u mount it mate. Yep ok will do. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted September 20, 2012 Share Posted September 20, 2012 Yours must be diff that mine mine mounts on a flat plate that slides up the side of the bottle...does your have fixing holes on the bottle itself. Yeah it has a fixing hole in the top corner, and the fixing on the side Quote Link to comment Share on other sites More sharing options...
DaveR Posted September 20, 2012 Share Posted September 20, 2012 Just bought one from a member mate En route shortly...! Quote Link to comment Share on other sites More sharing options...
listy Posted September 20, 2012 Share Posted September 20, 2012 The expansion tank doesnt "have" to be relocated. Mine is still in stock position, with stock bracket. Its just held on with one bolt instead of two, and the bracket has been bent to allow the tank to sit above the fmic. Quote Link to comment Share on other sites More sharing options...
DaveR Posted September 20, 2012 Share Posted September 20, 2012 An alternative is to mount the stock bottle longitudinally beneath the o/s headlight. It's not the most ideal location as you have to remove the headlight every time you want to check the level in the tank, but it is neat and out of the way. Bit of a hijack coming up: KaanW if you want the HKS relocation kit for the stock expansion tank that allows you to do all of that easily let me know and I'll send that with it. Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted September 24, 2012 Share Posted September 24, 2012 Ok. Thats probably why I dont have one and have just the pipe and cap hanging loose That made me chuckle Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 24, 2012 Share Posted September 24, 2012 Mines from a Honda Civic i think Quote Link to comment Share on other sites More sharing options...
