2 questions .one about fuel pump and the other about oil in Auto gear box
mclarenross
Hi All,
a couple of questions, see if anyone can help me out.....
1. I've just finshed installing my 1jzgte and I've put a new fuel pump in, however when I turn the ignition, the pump starts up and just keeps going, if I listen to the fuel rail it just sounds like it is continously gushing through the rail.. my friend said it might be the fuel relief value stuck open... not sure if these engines have one and if anyone has come across this before?
2. I was putting new auto transmittion fluid in the gearbox last night, ( i read on here that the box takes about 8 litres...!) I had put about 3-4 litres in the box, down through a long funnel, however when I took the funnel out for a minute, loads of fluid started coming back out.... anyone know how I can fill up the gearbox further or is it already full?
do I need to move the selector around, or if when I fire it up it'll pump the fluid around the box...??
any help would be grateful.
Ross
2. You can only exchange the volume of the gearbox sump using that method. This is usually about 2L's drain the sump again till the filler pipe has the oil level down to the max line.
To change all 8l's in one hit requires an autobox specialist with a positive displacement pump and a ramp. As you basically run the car in drive, pump fresh oil in through the rad cooler intake hose and fire out the rad cooler exit all the old oil.
1. I think thats normal, but i'd wait for another opinion.
Edited by Alex (see edit history)
  • 2 weeks later...
