Guest spyrosis Posted September 18, 2012 Share Posted September 18, 2012 hello all I,m totaly in the dark why my Red warning light stays on. I had the code 42 and i soldert the 2 wires together but when is turned the car back on the Red warning light turned on strait away so i did a new readout on the diagnosesysteem en nothing it sais there are no error messages does someone have or had the same problem as me does someone have a tip on what to do next or did someone had the same problem and knows what it is i really hope that there is ennybody that can help me thanks in advance for enny tips/help/solutions mathieu Link to comment Share on other sites More sharing options...
Marcus GTE Posted September 18, 2012 Share Posted September 18, 2012 Is your door shut? Link to comment Share on other sites More sharing options...
listy Posted September 18, 2012 Share Posted September 18, 2012 Did you get the error codes cleared? Link to comment Share on other sites More sharing options...
Havard Posted September 18, 2012 Share Posted September 18, 2012 The read warning triangle could be anything on the car. Door contact open/faulty, low brake fluid, handbrake on etc. Do you have any bulbs out? H. Link to comment Share on other sites More sharing options...
Dnk Posted September 18, 2012 Share Posted September 18, 2012 Low oil level, brake fluid, handbrake, door open, ash tray full etc etc Link to comment Share on other sites More sharing options...
Guest spyrosis Posted September 18, 2012 Share Posted September 18, 2012 (edited) oil level, brake fluid, handbrake all is ok everything is as it should fluidwise did a reset (disconected the battery ) and i driven it for a few miles aswell didn't went fast ( damm rain) and its only the red exclamation mark thats is on no other lights are turned on that tell you there is sonething wrong but light stays on i'm kinda scared i break something its no fun with that light staring at you like that Edited September 18, 2012 by spyrosis (see edit history) Link to comment Share on other sites More sharing options...
Suprab1 Posted September 18, 2012 Share Posted September 18, 2012 I've had my supra for about 7 years & only noticed that light about a year ago. It never worked so i checked the bulb, it had been taking out. I replaced it & the light stayed on so i just took it back out again. I've never had a problem with my supra but after reading this my door was probably open so i must check it again. Link to comment Share on other sites More sharing options...
Josh Posted September 19, 2012 Share Posted September 19, 2012 Low oil level, brake fluid, handbrake, door open, ash tray full etc etc Off topic, but does it really come on when the ash tray is full? Link to comment Share on other sites More sharing options...
Suprab1 Posted September 19, 2012 Share Posted September 19, 2012 Off topic, but does it really come on when the ash tray is full? Link to comment Share on other sites More sharing options...
Marcus GTE Posted September 19, 2012 Share Posted September 19, 2012 No. No it doesn't. Link to comment Share on other sites More sharing options...
