Red warning light stays on
Guest spyrosis
Guest spyrosis
hello all
I,m totaly in the dark why my Red warning light stays on.
I had the code 42 and i soldert the 2 wires together
but
when is turned the car back on the Red warning light turned on strait away
so i did a new readout on the diagnosesysteem en nothing
it sais there are no error messages
does someone have or had the same problem as me
does someone have a tip on what to do next
or did someone had the same problem and knows what it is
i really hope that there is ennybody that can help me
thanks in advance for enny tips/help/solutions
mathieu
Guest spyrosis
oil level, brake fluid, handbrake
all is ok everything is as it should
fluidwise
did a reset (disconected the battery )
and i driven it for a few miles aswell
didn't went fast ( damm rain):diablo:
and its only the red exclamation mark thats is on
no other lights are turned on that tell you there is sonething wrong
but light stays on i'm kinda scared i break something
its no fun with that light staring at you like that
Edited by spyrosis (see edit history)
I've had my supra for about 7 years & only noticed that light about a year ago. It never worked so i checked the bulb, it had been taking out. I replaced it & the light stayed on so i just took it back out again. I've never had a problem with my supra but after reading this my door was probably open so i must check it again.
