Jellybean Posted September 18, 2012 Share Posted September 18, 2012 Hey Tested my OEM Aerial and she just pops up about 8cm then retracts; can you recommend an Aerial , is it possible to leave the OEM as is and use an internal aerial fixed to the rear Glass? Or would you recommend getting a used working aerial? thanks Link to comment Share on other sites More sharing options...
Lee P Posted September 20, 2012 Share Posted September 20, 2012 The only Aerial that works properly is the stock one, if its only going up a bit then it may need a new mast. You can buy these from Toyota and they are not too expensive. Any of these shorter aerials or window mount aerials will not work very well. Link to comment Share on other sites More sharing options...
Jellybean Posted September 21, 2012 Author Share Posted September 21, 2012 Thanks Lee! Link to comment Share on other sites More sharing options...
