J-Meiser Posted September 17, 2012 Share Posted September 17, 2012 Good evening everyone, I have a quick question - if too much oil is in an engine (i.e. the level is way above the full mark on the dipstick) can it cause a leak? Link to comment Share on other sites More sharing options...
keron Posted September 17, 2012 Share Posted September 17, 2012 Depends how much over really. Common leaks on the supra can be front main crank seal, oil pressure switch, oil filter housing seal....or most common rocker cover gaskets.... Link to comment Share on other sites More sharing options...
keron Posted September 17, 2012 Share Posted September 17, 2012 Btw i went to see a car once, the chap had filled the engine oil to the cap so the whole engine was full! no wonder he said he could not start it! Fool.... Link to comment Share on other sites More sharing options...
Kaan W Posted September 17, 2012 Share Posted September 17, 2012 Btw i went to see a car once, the chap had filled the engine oil to the cap so the whole engine was full! no wonder he said he could not start it! Fool.... Link to comment Share on other sites More sharing options...
Swampy442 Posted September 17, 2012 Share Posted September 17, 2012 Holy crap! Link to comment Share on other sites More sharing options...
Abz Posted September 17, 2012 Share Posted September 17, 2012 Btw i went to see a car once, the chap had filled the engine oil to the cap so the whole engine was full! no wonder he said he could not start it! Fool.... Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 18, 2012 Share Posted September 18, 2012 Btw i went to see a car once, the chap had filled the engine oil to the cap so the whole engine was full! no wonder he said he could not start it! Fool.... Really? Link to comment Share on other sites More sharing options...
DaveR Posted September 18, 2012 Share Posted September 18, 2012 Btw i went to see a car once, the chap had filled the engine oil to the cap so the whole engine was full! no wonder he said he could not start it! Fool.... Excellent! Link to comment Share on other sites More sharing options...
stevie_b Posted September 18, 2012 Share Posted September 18, 2012 Bleed some out of the sump drain hole until the level is at the max mark. Unless you wrap your sump nut with PTFE tape (I've heard it's unwise to do this anyway) then it'll only take a few minutes. If it's "way above" like you say, it's not worth the risk of popping a seal or causing other problems by leaving it. Link to comment Share on other sites More sharing options...
mellonman Posted September 18, 2012 Share Posted September 18, 2012 Btw i went to see a car once, the chap had filled the engine oil to the cap so the whole engine was full! no wonder he said he could not start it! Fool.... HAHA what a dip stick! or not as the case maybe Link to comment Share on other sites More sharing options...
Dnk Posted September 18, 2012 Share Posted September 18, 2012 Or if you have one vacuum bleed some out via the dipstick tube Link to comment Share on other sites More sharing options...
J-Meiser Posted September 18, 2012 Author Share Posted September 18, 2012 Depends how much over really. Common leaks on the supra can be front main crank seal, oil pressure switch, oil filter housing seal....or most common rocker cover gaskets.... This one relates to my V8 Soarer, but I wanted to get a general idea before going into specifics. It only seems to leak when the engine is running. I'll get a picture up of the reading from the dipstick when I get home this evening, if it will help at all. Bleed some out of the sump drain hole until the level is at the max mark. Unless you wrap your sump nut with PTFE tape (I've heard it's unwise to do this anyway) then it'll only take a few minutes. If it's "way above" like you say, it's not worth the risk of popping a seal or causing other problems by leaving it. Thanks for the tip; I'll be doing the brakes on my IS200 this weekend so I'll get the Soarer out of the garage and give it a go. Or if you have one vacuum bleed some out via the dipstick tube Unfortunately not , but thanks for the tip anyway . Link to comment Share on other sites More sharing options...
keron Posted September 18, 2012 Share Posted September 18, 2012 if its only leaking while its started, its because of the pressure so could be something like oil pressure switch or fms maybe.... where is the leak comming from?? as in which area? Link to comment Share on other sites More sharing options...
J-Meiser Posted September 18, 2012 Author Share Posted September 18, 2012 I am yet to determine exactly where but would hazard a guess at the sump or just in front of it. I took a couple of pictures a few days ago when I noticed the oil on the floor but did not see any oil dripping. I then started it up, left it running for 5-10 mins, looked underneath and saw it dripping then. The pictures are not brilliant, but it was a spur of moment thing. I'll try and do a better job this weekend. Link to comment Share on other sites More sharing options...
stevie_b Posted September 18, 2012 Share Posted September 18, 2012 Ah, I didn't know you actually had an oil leak. Excess oil might have caused it, but now there's a leak that's likely to continue whether you remove some oil or not. I'd clean the area thoroughly, run the car for a bit, and look for the highest point that you can see the oil. Link to comment Share on other sites More sharing options...
Lee_e Posted September 18, 2012 Share Posted September 18, 2012 Cant the oil be whipped into a creamy colour by something in the engine if you over fill ? .. Swear I heard something like that not too long ago. Link to comment Share on other sites More sharing options...
stevie_b Posted September 18, 2012 Share Posted September 18, 2012 Lee: that happens when engine oil mixes with water (i.e. coolant). It's called emulsification. Caused by the head gasket breaking down, but not really by overfilling alone. Link to comment Share on other sites More sharing options...
J-Meiser Posted September 19, 2012 Author Share Posted September 19, 2012 Ah, I didn't know you actually had an oil leak. Excess oil might have caused it, but now there's a leak that's likely to continue whether you remove some oil or not. I'd clean the area thoroughly, run the car for a bit, and look for the highest point that you can see the oil. Thanks Stevie, I'll give it a go. The pic below gives an idea how much oil is in the system and the red line shows where it read on the dipstick; why so much was put in there I don't know but a lot of it is definitely going to have to go! Link to comment Share on other sites More sharing options...
Lee_e Posted September 19, 2012 Share Posted September 19, 2012 Lee: that happens when engine oil mixes with water (i.e. coolant). It's called emulsification. Caused by the head gasket breaking down, but not really by overfilling alone. Thanks bud.. I already knew that .. I was just stating that too much oil could cause that problem.. I know it was nothing to do with this mans leak but i just thought id stick my (very limited) knowledge in . Link to comment Share on other sites More sharing options...
stevie_b Posted September 20, 2012 Share Posted September 20, 2012 J-Meiser: I'd definitely run some oil out of the sump drain. I wouldn't be comfortable with it being that high. Link to comment Share on other sites More sharing options...
J-Meiser Posted September 20, 2012 Author Share Posted September 20, 2012 J-Meiser: I'd definitely run some oil out of the sump drain. I wouldn't be comfortable with it being that high. It is on my "To-do" list for Saturday. Thankfully, this car is not started up often at all as I'm trying to sort out various other issues first. Link to comment Share on other sites More sharing options...
Batmax Posted September 20, 2012 Share Posted September 20, 2012 You need to see first were the oil appear, one time I have an leak on mine guess what was an oring between engine and the rond part were the oil filter attach but was small looses of oil, GL. Link to comment Share on other sites More sharing options...
