Batmax Posted October 4, 2012 Author Share Posted October 4, 2012 Yes noise stops, only left change that one you are talking these right ? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 4, 2012 Share Posted October 4, 2012 Yes probably uneven wear on the ball inside this joint. You need to change the whole arm. If you buy new you COULD buy the later VVTi ones, they have less compliance in the inner bushings, fore and aft. They are a straight swap. Link to comment Share on other sites More sharing options...
Batmax Posted October 4, 2012 Author Share Posted October 4, 2012 Thanks a lot, I will buy an used from keron to see if is really these part hope so because my ego is now at 0 lol. Link to comment Share on other sites More sharing options...
Batmax Posted October 4, 2012 Author Share Posted October 4, 2012 One question when I was think I have found the problem the rack ball joint as grease coming to outside, I would guess I can rebuild the interior with new grease and put the rubber, anyone have instructions how can I do these once my end tie rod is fine just need to rebuild the grease and sealed with the rubber ? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 4, 2012 Share Posted October 4, 2012 It's quite usual for them to ooze some grease. I will almost certainly have a KNOWN good used lower arm if you want one. Which side is it that's maybe making the noise? Link to comment Share on other sites More sharing options...
Batmax Posted October 4, 2012 Author Share Posted October 4, 2012 Right side, please see if you have one, thanks. Link to comment Share on other sites More sharing options...
Batmax Posted October 5, 2012 Author Share Posted October 5, 2012 (edited) Ok, tonight I raise my forces I get start to get all out, incluing lower control arm, I have noticed that was a lot of anti gravel unfortunately the guy who paint my Supra put there anti gravel too what noob, so I start to clean also when I move down the arm I notice the same noise but I didn't have change to test the car because was too late and will do a lot of noise for my family was slipping lol, I test the lower control ball joint imo is fine. When I start to take the final studs I notice something very strange, please look at these pics of the camber is these right, I think there is here a big xhit job from the guy who get alignment my Supra ! I think it is betther next time change these nut what you think is ok ot not, I got in the end squeezes it with some difficulty but was tight (228mn) Edited October 5, 2012 by Batmax (see edit history) Link to comment Share on other sites More sharing options...
Batmax Posted October 5, 2012 Author Share Posted October 5, 2012 (edited) Next stage, install all again, I take the risk and put the camber like these are these ok ? And the men Behind Edited October 5, 2012 by Batmax (see edit history) Link to comment Share on other sites More sharing options...
caracol Posted October 5, 2012 Share Posted October 5, 2012 Any news Nuno?? Link to comment Share on other sites More sharing options...
Batmax Posted October 5, 2012 Author Share Posted October 5, 2012 Victory Finnally !!!!!!!!!!!!!!!! :D:D:D:D:D:D:DD:D: :):):) Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 5, 2012 Share Posted October 5, 2012 Well done. You should have Tipex marked the eccentric snails before loosening them, then you could have returned the geo very close to how it was before. If you want to change the arm I have both sides in stock. Link to comment Share on other sites More sharing options...
Batmax Posted October 5, 2012 Author Share Posted October 5, 2012 Well done. You should have Tipex marked the eccentric snails before loosening them, then you could have returned the geo very close to how it was before. If you want to change the arm I have both sides in stock. Thanks , but the alignment was wrong right ? If you look in these they, have forced the metal side ! At the moment I don't have any noise anymore finally , thanks any way for you dispose I appreciate a lot your help . I have center the camber and will take the car to get alignment again, any idea what could be good for 19 wheels ? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 5, 2012 Share Posted October 5, 2012 I have center the camber and will take the car to get alignment again, any idea what could be good for 19 wheels ? The bin? Link to comment Share on other sites More sharing options...
Batmax Posted October 5, 2012 Author Share Posted October 5, 2012 For these, I have center more closely possible an then will get again aligment at my supervision for they do not make the same mistake : The oval metal pieces are market in degrees right, there any problem if I center the 2 front wheels like photo above, because left wheel and camber should have the same issue ? Link to comment Share on other sites More sharing options...
Batmax Posted October 12, 2012 Author Share Posted October 12, 2012 And these is the end result of alignment, great values imo, what you think ? Once again, BIG THANKS for those who try help me, you are like a family to me and my Supra F R Link to comment Share on other sites More sharing options...
lamboyello Posted October 30, 2012 Share Posted October 30, 2012 The problem for me was just a loose adjuster Link to comment Share on other sites More sharing options...
Batmax Posted October 30, 2012 Author Share Posted October 30, 2012 it sucks lol Link to comment Share on other sites More sharing options...
Hartmann Posted October 30, 2012 Share Posted October 30, 2012 great news bud Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 30, 2012 Share Posted October 30, 2012 so the arms cured the noise ? Link to comment Share on other sites More sharing options...
Batmax Posted October 30, 2012 Author Share Posted October 30, 2012 If I clean first the lower arm and torque it well first, I wouldn't spend any money lol Link to comment Share on other sites More sharing options...
