p3te Posted September 16, 2012 Share Posted September 16, 2012 the last few times ive drove my car Ive noticed a loud rattle coming from the turbo area, sometimes it does it but most the time it dosent, still boost fine and has no smoke, ill not get the chance to check it out till at least next weekend now, in the meantime what do yous think it could be? possible just loose bolt rattling somewhere? what sound do the turbos make when they fail? heres a quick vid, you cant see anything as i just pulled over when i heard it for a quick listen http://www.youtube.com/watch?v=zdQpfKoLiu0&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 16, 2012 Share Posted September 16, 2012 If you are boosting fine, it shouldn't be the turbos. Also being stationary even if the turbos were playing up you can't tell until you drive it. I'm taking a stab in the dark maybe its the heat shield? Best wait till morning and investigate a little more then. Quote Link to comment Share on other sites More sharing options...
p3te Posted September 16, 2012 Author Share Posted September 16, 2012 If you are boosting fine, it shouldn't be the turbos. Also being stationary even if the turbos were playing up you can't tell until you drive it. I'm taking a stab in the dark maybe its the heat shield? Best wait till morning and investigate a little more then. im hoping its just that too, was too dark to see at the time, i just fitted the heat shield the other week one of the bolts might have come loose Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 16, 2012 Share Posted September 16, 2012 I have something similar to this going on too but only when I lift off the gas and its in gear. Dip the clutch or apply a bit of throttle and it goes. Shouldn't be the clutch as I had it all changed last year with OEM stuff. Watching this thread with interest.... Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 16, 2012 Share Posted September 16, 2012 http://www.mkivsupra.net/vbb/showthread.php?20059-Actuator-Rattle&highlight=rattle could be this? Quote Link to comment Share on other sites More sharing options...
p3te Posted September 17, 2012 Author Share Posted September 17, 2012 http://www.mkivsupra.net/vbb/showthread.php?20059-Actuator-Rattle&highlight=rattle could be this? Could well be, is this the little actuator in the top turbo pipe? I've noticed sometimes this sticks open Quote Link to comment Share on other sites More sharing options...
p3te Posted September 17, 2012 Author Share Posted September 17, 2012 Could well be, is this the little actuator in the top turbo pipe? I've noticed sometimes this sticks open so is it an actuator on the downpipe? accessed from under the car? reading that thread they cant be easily replaced? Quote Link to comment Share on other sites More sharing options...
p3te Posted September 22, 2012 Author Share Posted September 22, 2012 Just looking at this now it is the rod rattling on the nownpipe, what's the best way to sort this? Looking at some posts some wrap it to dampen the sound but that isn't advised and it can't be changed unless the turbo is changed because its attached is that right? Quote Link to comment Share on other sites More sharing options...
p3te Posted September 23, 2012 Author Share Posted September 23, 2012 anyone? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted February 22, 2014 Share Posted February 22, 2014 Did you ever solve this? Mine is now rattling that side when reved at idle after being parked up for 4 months. Quote Link to comment Share on other sites More sharing options...
p3te Posted February 27, 2014 Author Share Posted February 27, 2014 yes it was the actuator on the down pipe, i think a hose had popped off somewhere stopping it moving so the rod was rattling Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted February 27, 2014 Share Posted February 27, 2014 Think mine was the egcv actuator rod too, which has now been fixed open as I run permanent TTC Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted February 28, 2014 Share Posted February 28, 2014 I have plumbed back to seq mode. Sadly car isnt taxed so cant test. Although cant replicate the noise on the Driveway when revving engine to 2k rpm. This was when I noticed the noise initially in ttc. Quote Link to comment Share on other sites More sharing options...
