HELP please : loud tiking noise from coils/head area
ray007
Hi all
Been having on going problems with my project, 2jzgte jap spec prefacelft
Initially I've been having problems with startin due to slight over-fueling/plugs getting wet and carbon deposits on them (new plugs)
I did have the fuel pump running at 12v constant mod wich I've put back to stock, installed a new lambda as well.
Now when startin the car with clean plugs, when turned off again the plugs needed cleaning of the carbon deposits before it could start, so I took out the plugs and cleaned them and re-installed... The car still took a long time to start but now there is a loud ticking/clicking noise seems to be coming from either the coils or injectors, and it gets louder as revved higher
Has it by anychance got to do with the ecu (as I disconnected the batter)? Or maybe a faulty coil?
I've constantly had the over fueling problem but never the ticking
Any advice would be much appreciated
Thanks in advance :-)
Edited by ray007 (see edit history)
  • 2 weeks later...
Guest Tayousei
As one guy above mentioned, maybe you are having valve train noise from too large of a shim to cam clearance. It would go "tap-tap-tap-tap-tap" and speed up with engine revs as well. Might need a taller shim on one or a few lifters. Or oil could be low. Post a video?
