BenRichardsFife Posted September 16, 2012 Share Posted September 16, 2012 hey guys, my car makes a horrible whirring noise when started from cold. its coming from the apexi air filter that my car has installed on it. i took a video which shows the noise a bit more clearer (the video is from a dead cold start) http://youtu.be/ofAV66RTf8E it dies down after the car heats up and practically disappears, but obviously it would be a good idea to sort it because it will most probably be affecting the intake of air to the engine right, im guessing the air filter obviously needs replaced, or can the filter be cleaned etc? or is it a definite replacement job. any help its appreciated, Ben Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 16, 2012 Share Posted September 16, 2012 What you should really do is buy my stock air box and ducting Shameless plug there. All joking aside mate if you want to keep anon genuine filter then give it a clean. You can buy special cleaner for cone filters, simply spray it on, wash it off, leave to dry then re fit it. If that doesn't work then I would buy a new one cant be that expensive i wouldnt have though. May even be cost affective to just go for a new one anyway. Quote Link to comment Share on other sites More sharing options...
BenRichardsFife Posted September 16, 2012 Author Share Posted September 16, 2012 haha so tempting... but i'll pass man, thanks for the info dude! Quote Link to comment Share on other sites More sharing options...
supra joe Posted September 16, 2012 Share Posted September 16, 2012 Hats normal for an aftermarket cone filter, mine does the same. Gonna change back to stock airbox, when I find a cheap enough one. Quote Link to comment Share on other sites More sharing options...
BenRichardsFife Posted September 16, 2012 Author Share Posted September 16, 2012 Hats normal for an aftermarket cone filter, mine does the same. Gonna change back to stock airbox, when I find a cheap enough one. is it just wear and tear i take it? how long do aftermarket cones usually last, mines was on the car when i bought it so i dont know how old mines is :[ Quote Link to comment Share on other sites More sharing options...
supra joe Posted September 16, 2012 Share Posted September 16, 2012 is it just wear and tear i take it? how long do aftermarket cones usually last, mines was on the car when i bought it so i dont know how old mines is :[ No bud not wear and tear, mine has a new filter on and its just the way the air is being sucked through the cone filter, go stock airbox if you can as its proved to be better than aftermarket cone filters, stick an oem panel filter in the sock airbox for the win Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 16, 2012 Share Posted September 16, 2012 Apexi cone filters from http://www.frsport.com Quote Link to comment Share on other sites More sharing options...
straightsix Posted September 16, 2012 Share Posted September 16, 2012 1. The sound is normal for a cone filter. 2. If you're not going to change it, at least take it off and tap the muck out of it. It looks pretty choked. 3. What's the thing that looks like a brass union on the alloy intake pipe?? Cap it off if it's not being used. 4. Your IAT sensor isn't much use cable tied to the wiring loom like that. It ought to be fitted into the intake pipe. Quote Link to comment Share on other sites More sharing options...
BenRichardsFife Posted September 16, 2012 Author Share Posted September 16, 2012 3. What's the thing that looks like a brass union on the alloy intake pipe?? Cap it off if it's not being used. it is capped off man 4. Your IAT sensor isn't much use cable tied to the wiring loom like that. It ought to be fitted into the intake pipe. i have no idea why its tied up, but its been like that since i got it? :[ haha, when you say plug it into the intake pipe, are you talking about the apexi one? thanks for the info dude Quote Link to comment Share on other sites More sharing options...
straightsix Posted September 16, 2012 Share Posted September 16, 2012 Difficult to tell if it's capped in the vid Yes - get hold of the rubber grommet that it would sit in it the stock pipe (I might have a spare but someone should have one knocking around), drill a hole of suitable size, locate the grommet then fit the sensor. Simple If you have access to an airline, blow all the crud out of your filter too! Quote Link to comment Share on other sites More sharing options...
BenRichardsFife Posted September 16, 2012 Author Share Posted September 16, 2012 thanks for your help buddy! Quote Link to comment Share on other sites More sharing options...
