Lude Posted September 15, 2012 Share Posted September 15, 2012 ordered a new water temperature sensor from toyota, the ECU one that goes in the bottom of the radiator. disapointed after paying £50 for it, for a genuine one, its the wrong one. i ordered the part number after reading it on here. are they different for NA to TT? its the larger one i need, has 2 prongs in. part number i had was 89422-35010 hope toyota will return exchange it for me as it says no refunds on the receipt Quote Link to comment Share on other sites More sharing options...
Shane Posted September 15, 2012 Share Posted September 15, 2012 Dude, I think you have it wrong. The sensor in the bottom of the rad is for the electric fan that comes in when the viscous fails or cant cope. Its a normally closed sensor that triggers a relay down on the front chassis leg in front of the passenger headlight. What makes you think that its the sensor for the ECU? Quote Link to comment Share on other sites More sharing options...
Lude Posted September 15, 2012 Author Share Posted September 15, 2012 Read it on here there were 2 sensors, one for the ecu and one for the temp gauge in the dash??? Wheres the water temp sensor for the ecu then? I may have the correct one from toyota then. So i take it there are three sensors all together? Ecu, dash gauge, and the emergency electric one Quote Link to comment Share on other sites More sharing options...
Lude Posted September 16, 2012 Author Share Posted September 16, 2012 Ah found it. Iv put the new sensor in the correct place now fit straigjt in :-) Wish i knew yesterday before i emptied the coolent from it lol. The sensor in the rad, does that effect the car at all or does it just trigger the mini fan to come on when temps are high.. Quote Link to comment Share on other sites More sharing options...
Shane Posted September 16, 2012 Share Posted September 16, 2012 You should have a bigger electric fan in front of the radiator? The sensor in the rad is for that. I am not sure how the smaller fan on the engine side is switched, I think that is linked to the AC. Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted September 16, 2012 Share Posted September 16, 2012 Im still trying to find it where is it located in the end mate? Quote Link to comment Share on other sites More sharing options...
Shane Posted September 16, 2012 Share Posted September 16, 2012 There's two sensors on the TT. Both at the front of the engine above the water pump and adjacent to the thermostat housing. One has a single wire and I would think this is the gauge sensor, the other has two wires and this would be the sensor for the ECU. I don't know for the na but can't imagine its that different. I have an old na lump here, if you can't find them then let me know and I will have a look. Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted September 17, 2012 Share Posted September 17, 2012 Ok i think im being very dim here i still cant find it! If you could have a look for me mate that would be brilliant? Quote Link to comment Share on other sites More sharing options...
Lude Posted September 19, 2012 Author Share Posted September 19, 2012 Il take a pic for you tonight mate :-) It is tucked.awau slightly but very easy to get to and replace Seems to have sorted my starting issue too :-) Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted September 19, 2012 Share Posted September 19, 2012 Cheers mate I'm hoping it will sort the starting issues for this one I'm working on as well. What starting issues were you having? Quote Link to comment Share on other sites More sharing options...
Lude Posted September 19, 2012 Author Share Posted September 19, 2012 http://www.mkivsupra.net/vbb/showthread.php?276526-car-difficult-to-start-after-short-trips-or-when-warm on page three there is a vid. Not sure if mines 100% but seems better. Will post up where it is later mate Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted September 22, 2012 Share Posted September 22, 2012 Any luck with where this is? Quote Link to comment Share on other sites More sharing options...
Lude Posted September 22, 2012 Author Share Posted September 22, 2012 (edited) here is where it is mate. looking from straight on at the engine, as you lift the bonnet. its to the bottom left corner of the engine..... Edited September 22, 2012 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
