Marco79 Posted September 15, 2012 Share Posted September 15, 2012 Having just bought an NA-T setup as an 'intro' engine to my project before putting in my fully built gte block I'm looking at converting the GE ignition system to GTE to make the engine swop easier come the time. The car is a blank canvas so it's a good time to do this. What parts do I require to achieve this and is there any known problems I will encounter doing this? Appreciate any help with this Link to comment Share on other sites More sharing options...
Swampy442 Posted September 15, 2012 Share Posted September 15, 2012 Id say it would be nigh on impossible to convert to the GTE system, much easier to get a GTE engine and ECU and slap that in. Link to comment Share on other sites More sharing options...
Marco79 Posted September 15, 2012 Author Share Posted September 15, 2012 Id say it would be nigh on impossible to convert to the GTE system, much easier to get a GTE engine and ECU and slap that in. Really I've an aftermarket ecu that can be programmed to control the spark so I just figured with a TT loom, coil packs and a maf map sensor change something could be thrown together lol Already got a GTE engine but that's the next phase when ive got used to the car and 500bhp then in goes the expensive built engine running upwards of 800bhp Just signed upto club na-t to see if they can offer any insight as I'm sure it's been done Link to comment Share on other sites More sharing options...
tkddav3 Posted September 15, 2012 Share Posted September 15, 2012 im running coils on mine and a dizzy delete ish Link to comment Share on other sites More sharing options...
mattdavies Posted September 15, 2012 Share Posted September 15, 2012 Didnt realise you were NA-T Dave With a supporting loom i dont see why you shouldnt be able to run coilpacks via your ECU, it will need mapping though Link to comment Share on other sites More sharing options...
tkddav3 Posted September 15, 2012 Share Posted September 15, 2012 Didnt realise you were NA-T Dave With a supporting loom i dont see why you shouldnt be able to run coilpacks via your ECU, it will need mapping though indeed i am matt, im not finished in the numbers department just yet and as matt said you can run coilpacks with your ecu, im running mine with the syvecs and ryan did the mapping Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 15, 2012 Share Posted September 15, 2012 indeed i am matt, im not finished in the numbers department just yet and as matt said you can run coilpacks with your ecu, im running mine with the syvecs and ryan did the mapping I didn't know either! Link to comment Share on other sites More sharing options...
Marco79 Posted September 15, 2012 Author Share Posted September 15, 2012 indeed i am matt, im not finished in the numbers department just yet and as matt said you can run coilpacks with your ecu, im running mine with the syvecs and ryan did the mapping That's awesome news mate apart from adding coil packs was there anything else you changed mate? Link to comment Share on other sites More sharing options...
TRD-1 Posted September 15, 2012 Share Posted September 15, 2012 Marco its possible to run the GTE Ignition on a GE engine, its not overly difficult, will require u making a small custom wiring loom for the Ignitor and coilpacks. The best thread in the world that covers this is here Link to comment Share on other sites More sharing options...
Marco79 Posted September 15, 2012 Author Share Posted September 15, 2012 Marco its possible to run the GTE Ignition on a GE engine, its not overly difficult, will require u making a small custom wiring loom for the Ignitor and coilpacks. The best thread in the world that covers this is here Thanks for the link mate, as I'm essentially putting an NA into a Tt would I still need to add much to the loom? Link to comment Share on other sites More sharing options...
