Guest matthew14 Posted September 13, 2012 Share Posted September 13, 2012 every time i press the clutch down it makes a loud sqweek it worts fine apart from that anyone have any ideas on a fix? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 13, 2012 Share Posted September 13, 2012 Common problem this is it a w58 by any chance? Is the squeak from inside the car (Pedal) or out side Gearbox arm. I have the latter and if you get under the car and get some lube on the arm, while someone pumps the clutch, it should help but its not a permanent fix but should cause no problems apart from annoying you that is. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted September 13, 2012 Share Posted September 13, 2012 Glad to read this thread as mine annoys me, It goes away after a little while though, Makes a good excuse to turn the music up a notch I suppose. Quote Link to comment Share on other sites More sharing options...
