J_Supra_07 Posted September 12, 2012 Share Posted September 12, 2012 Hey guys I have had a constent isuse with my turbo return pipe. fist was melting uses but after installing a Garage Whifbitz return pipe it not melting any more. But when hot it leaks at top. I have had it off and on four times now. really getting fed up. Is buying a diffrent pipe the answer? othe then that i am tempted to weld the joints together. Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted September 12, 2012 Share Posted September 12, 2012 Should of gone NA-T, tut tut Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted September 12, 2012 Share Posted September 12, 2012 Silly question... But you got a gasket on the flange? Quote Link to comment Share on other sites More sharing options...
black_widow87 Posted September 12, 2012 Share Posted September 12, 2012 Where abouts on the pipe is it leaking? Any pics? Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted September 13, 2012 Author Share Posted September 13, 2012 lol at the n/a t remark. Yeh it got a gasket mate. not leaking there. the Garage Whifbitz return pipe kit comes with a ali pipe that bolts to the turbo then the return pipe tightens to that. Iv had it off 4 times trying to get the thing to stop but still leaks. Ill whip it off again this weekend and coat the thread in gasket seal then try that is it dont work ill weld the joint i think. Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted September 13, 2012 Author Share Posted September 13, 2012 Where abouts on the pipe is it leaking? Any pics? its seeping out at the joint for the ali pipe and the braided hose. and trust me it wont do up any tighter without snaping the ali. they are spos to salf seal these fittings but leaked so iv tryed PT tape, blue seal, and lock tight all dont seem to have stoped it so iam going to try high temp gasket seal next. if that falls iam tempted to weld the joints up. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 13, 2012 Share Posted September 13, 2012 use ptfe on it mate Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted September 13, 2012 Author Share Posted September 13, 2012 use ptfe on it mate Done that mate didt work. Its not a huge leak but it so annoying as id like to keep the under side of my car clean. I toped it up 3 weeks ago and it still showing full on the stick thats how small a leak it is. but i want it fixed. You know me i hate it if its not right. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 13, 2012 Share Posted September 13, 2012 get the welder out Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted September 14, 2012 Share Posted September 14, 2012 get the welder out Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted September 15, 2012 Author Share Posted September 15, 2012 Lol it coming off soon after it cools down from morning play. Will let you know how I get on Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted September 15, 2012 Author Share Posted September 15, 2012 Well all sorted now. Did fair bit this morn Sealed the return pipe up again, fingers crossed be the last time I take it off. Found a small water leak so sorted that. Adjusted the clutch pedal hight, never been right since I fitted the new master cylinder. Changed all my coil pack connectors. And started wire tucking some bits. :-) Feel good now. Iam happy there no little things that need doing any more. Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted September 16, 2012 Author Share Posted September 16, 2012 This pipe has put me in one of the moods when u hate cars. Still seeping. Going to weld it up Quote Link to comment Share on other sites More sharing options...
