Brothy Posted September 10, 2012 Share Posted September 10, 2012 (edited) Hey guys, got a bit of a problem i thought i solved, the drivers rear side brakes or wheel makes a creek noise, i also noticed when i taken my wheel off that my caliper tends to wobble in and out wen the the disc is rotating, there are crappy jspec calipers, any ideas ? Edited September 10, 2012 by Gaz6002 Better thread title (see edit history) Quote Link to comment Share on other sites More sharing options...
Westy Posted September 10, 2012 Share Posted September 10, 2012 Wheel bearing Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 10, 2012 Share Posted September 10, 2012 Whats the disc held to the hub with once you have taken the wheel off, is it loose or held in place by small screws Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 10, 2012 Author Share Posted September 10, 2012 There is nothing securing the disc to the hub, never was since ive owned the car, yeah the disc has a slight bit of play Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 10, 2012 Share Posted September 10, 2012 (edited) Put 3 or 5 wheel nuts on the studs and nip them up to hold the disc true then rotate it Edited September 10, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 10, 2012 Author Share Posted September 10, 2012 I will try that, if the the disc rotates fine and there is no wobble on the caliper, any ideas what the creeking could be wen the wheel is rotated Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 10, 2012 Share Posted September 10, 2012 Is this with the wheel off the ground and just rotating by hand ? Could be the handbrake inside the disc, wheel bearing, driveshaft CV joint or the caliper is binding on the disc Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted September 10, 2012 Share Posted September 10, 2012 I've amended your thread title to make it easier for people to find in the future. Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 10, 2012 Author Share Posted September 10, 2012 The creeking is when i am driving, it starts of with a quiet creek then progressively gets louder over a short time, do you think i should let a garage check before i go chucking money at it ? Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 10, 2012 Author Share Posted September 10, 2012 Thanks alot gaz Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 10, 2012 Share Posted September 10, 2012 (edited) The creeking is when i am driving, it starts of with a quiet creek then progressively gets louder over a short time, do you think i should let a garage check before i go chucking money at it ? Yes but take it to a good garage that actually know what their doing, most these days just change parts till they fix the problem If you put the wheel back on keep it in the air and check to see what it rotates like, any noise from the hub or caliper ? also hold the tyre at 9 and 3 and wobble the wheel to see if theres any play, do the same holding at 12 and 6 Does this wheel near the center feel any hotter than the other side after you've driven for a while ? use the back of your hand near to the wheel by the caliper to check for difference in heat showing a caliper is sticking Edited September 10, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 10, 2012 Author Share Posted September 10, 2012 No specific hot spots on the tyres, the disc is just as warm as the opposite side, wen the wheel is on and the car is in gear the wheel wobbles, a friend said this could be my wheel bearing ?? I do get a werring noise wen i make left turns amd goes wen i turn right Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 10, 2012 Share Posted September 10, 2012 If the wheel is wobbling then its either loose or the wheel bearing is failing but you should feel this with the test mentioned, your not checking the tyre for hot spots but play in the wheel bearing If you get the whirring noise changing as you turn left or right then this could be the wheel bearing failing Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 10, 2012 Author Share Posted September 10, 2012 Going have to get the bearing changed as its always made a werring noise from when i bought the car and take it from there Quote Link to comment Share on other sites More sharing options...
