Ball joint boot size
-Welsh-Stealth-
Was under the car the other day doing an oil change& also had a look over all 4 wheels. For play/movement in the bearings & ball joints.
All good, However I did notice a split in the N/S/R upper wishbone ball joint gaiter. The ball joints fine& I intend to keep it that way. So I will be replacing the boot/gaiter before anything has a chance to work it's way in there.
My question is:
What are the boot diameters?
Top& bottom hole, and length.
