Geo Posted September 9, 2012 Share Posted September 9, 2012 Spotted this on the car a few wks back, it was hunting for idle. Now it hunts between 300-1000rpm from a cold start, even when warmed at idle(not driven it will hunt) Today it started doing it again, but when i drive the car, she idles fine bang on 900rpm, and runs sweet? Im thinking IACV, so might pop it off and use my Own guide How to clean it out. Just wondering if there is anything else it could be, or to look for? cheers guys Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 9, 2012 Share Posted September 9, 2012 you could have a vac leak mate or IACV might need cleaning. if your BPU now mate my guess is most likely vac lines. Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 9, 2012 Share Posted September 9, 2012 Check for split vac pipes. Air leaks can cause erratic idle. Quote Link to comment Share on other sites More sharing options...
Geo Posted September 9, 2012 Author Share Posted September 9, 2012 you could have a vac leak mate or IACV might need cleaning. if your BPU now mate my guess is most likely vac lines. Check for split vac pipes. Air leaks can cause erratic idle. Not BPU yet bud, still completely stock, It goes away once the car is driven, and idles perfect. I'll have a look and see if i can see any splits in the Vac lines to be sure. Although i would have thought an air leak would cause the idle issue all the time? cheers guys Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 9, 2012 Share Posted September 9, 2012 something like this mate we advise on all bpu. http://www.ebay.co.uk/itm/Toyota-Supra-Silicone-Vacuum-Hose-kit-Blue-/220787393150 Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 9, 2012 Share Posted September 9, 2012 Not BPU yet bud, still completely stock, It goes away once the car is driven, and idles perfect. I'll have a look and see if i can see any splits in the Vac lines to be sure. Although i would have thought an air leak would cause the idle issue all the time? cheers guys ah then its your IACV and defo go for them vac lines mate for whe she BPU will make it easier Quote Link to comment Share on other sites More sharing options...
Geo Posted September 9, 2012 Author Share Posted September 9, 2012 something like this mate we advise on all bpu. http://www.ebay.co.uk/itm/Toyota-Supra-Silicone-Vacuum-Hose-kit-Blue-/220787393150 ah then its your IACV and defo go for them vac lines mate for whe she BPU will make it easier cool mate, i'll pull it off this wknd then and give it a good clean. Yeah i'll get them matey, BPU aint far away. cheers bud. Quote Link to comment Share on other sites More sharing options...
