dude Posted March 3, 2003 Author Share Posted March 3, 2003 Mark the water pump was easy enough once the bottom pulley was off , the turbo pipes are not to bad but the inlet was a bit fidly , gonna plop me uk injectors in while its off.hope i can remember where it all goes . John:flame Dev Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 3, 2003 Share Posted March 3, 2003 The inlet is tricky when it comes to seperating the throttle body from the manifold, and I also didn't take the cold start system off so just wired the manifold out the way while I swapped the injectors The turbo piping comes off in about two hours once you know what you are doing, the arsehole bit is removing the actual turbos, I don't ever want to have to do that again! I haven't done the crank pulley yet but that job is looming (nice unorthodox racing one to go on...), any hints and tips? Yeah, it's nice to see people have a stab at it, I mucked in with mine mainly for financial reasons, heh. If you are sticking in UK 550's, are you putting in a resistor pack of some sort...? -Ian Quote Link to comment Share on other sites More sharing options...
dude Posted March 3, 2003 Author Share Posted March 3, 2003 Ian the crank pulley is not too bad , i got mine off useing 2 large prybars and walked it off but it would be easy to make a puller using some thick iron bar with 2 holes drilled , undo the crank nut and use that to pull the bottom pulley off (as a lever ) the pulley has 2 holes either side that if you use to pull the bar onto the undun ? crank bolt will pull the pulley off (thats confusing isint it) im gonna fit a new resistor pack off a uk car , Ian can you look at my latest requests for help please. John:flame Dev Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 4, 2003 Share Posted March 4, 2003 Originally posted by dudersvr im gonna fit a new resistor pack off a uk car , Ian can you look at my latest requests for help please. John:flame Dev Er, where?! -Ian Quote Link to comment Share on other sites More sharing options...
