Noz Posted September 9, 2012 Share Posted September 9, 2012 Having some squeeks and noise come from lowest pulley on the aux belt on front of engine. Could this just be the bearings need replacing? Its pretty bad sometimes wont even start because of it. Quote Link to comment Share on other sites More sharing options...
Oddball87 Posted September 9, 2012 Share Posted September 9, 2012 Do you mean the crank pulley mate? Its the largest one on the engine. If so you will most prob need to replace the crank pulley because it will end up separating and can cause a lot of damage. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted September 9, 2012 Share Posted September 9, 2012 Sounds like the Crank Pulley bud, if it is, then don't mess around and get a new one, if it flies off it can wreck everything and you being NA-T it is going to be really expensive compared to just replacing the Pulley There is a Tippex test, but if it is wobbly then it's pretty much guaranteed to be dead http://www.mkivsupra.net/vbb/showthread.php?174726-O-Crap-Looks-light-my-Crank-pulley-is-going Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 9, 2012 Share Posted September 9, 2012 (edited) There are no bearings in the crank pulley and use a genuine pulley not a cheap aluminium one Their around £300 from Toyota Edited September 9, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
ashbuster Posted September 9, 2012 Share Posted September 9, 2012 this is exactly whats wrong with my car havent moved my car or started it since and im waiting for mine to come in the post. now i have a dead battery too that i have to replace. never have a problem starting it or any squeeks but since i noticed the wobble it hasnt been started Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 9, 2012 Share Posted September 9, 2012 The battery could just be flat, before you buy a new one jump start your car and take it for a 10 mile drive and when you get home you could find its re charged and fine. I suffer this with not using my car very much and its always been fine once its been driven. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted September 9, 2012 Share Posted September 9, 2012 i have put it on charge overnight will see what happens. i would have had it done now but still waiting for the pulley and i only have 1 and half weeks left to get it all finished. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 crap. yea would explain why she dont fire up sometimes. so no one else sells them apart from toyota? 300 quiddies, that's gonna rape my ass! Quote Link to comment Share on other sites More sharing options...
listy Posted September 9, 2012 Share Posted September 9, 2012 Whifbitz do factory copies mate. Circa £240 delivered. Its what I have on mine now after it went. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 oh...my...god. That sucks. When I get my coilover shock changed I'll get my mate to have a look and order a whifbitz one then. Arghhhh! So anonying. If I didn't have to fork out enough dosh already. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 9, 2012 Share Posted September 9, 2012 You don't need coilovers, you do NEED a crank pulley Quote Link to comment Share on other sites More sharing options...
listy Posted September 9, 2012 Share Posted September 9, 2012 Always happens when you least expect it dude I had my crank seal, oil pump, crank pulley, and the white van incident (hense respray) all happen within 10 weeks £3k gone right there! (including a bit of labour cost) Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 you didnt pay for white van costs though did you bud? just a new pulley and belt change is all thats needed with crank pulley replacement? Quote Link to comment Share on other sites More sharing options...
listy Posted September 9, 2012 Share Posted September 9, 2012 Might not even need the belt mate. But may as well change it while its off. Yeah had to pay for the white van damage. No CCTV and couldnt track the van down. I dont park outside that shop anymore lol Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 9, 2012 Share Posted September 9, 2012 Just to make sure it's the crank pulley do the tippex test Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 Ah bad times. I only had a new aux belt in may! And not done many miles. PITA! Though it's pretty cheap anyway. Bloody car... she better hit 400 when I get it tuned again or I'm gonna be miffed! Just to make sure it's the crank pulley do the tippex test Is this to see if the bearing moves inside the pulley then? Quote Link to comment Share on other sites More sharing options...
listy Posted September 9, 2012 Share Posted September 9, 2012 No bearing in the crank pulley mate. The pulley is in two parts, an outer and inner, which are bonded together. iirc the idea is to put a bit of tipex across the join where it is bonded, and run the car. If the tipex cracks, then the pulley is dead. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 ok good, dumb questions thanks for helping, ive never swapped parts like this so its new to me. Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 just used some perm marker as didnt have any tipex. it squeeked starting up. turned it off, lines have moved! Nooooooo! Can I not just weld them together? Quote Link to comment Share on other sites More sharing options...
listy Posted September 9, 2012 Share Posted September 9, 2012 No mate. Its bonded because its a dampened pulley. If you weld it, it will take the dampening effect away. Yours is the 4th or 5th I have seen go on the forum since mine. Think I started a trend Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 That sucks mate. How easy is it to get off? Did you do it? Quote Link to comment Share on other sites More sharing options...
listy Posted September 9, 2012 Share Posted September 9, 2012 Yeah did it myself mate. Hardest part is getting the bolt off. I used the breaker bar and starter motor trick to get mine off. Put the breaker bar with required size socket on the bolt, and have the other end of the bar on the floor on the PASSENGER side. Turn the key in the ignition so the starter motor turns. DO NOT LET THE CAR TURN OVER!!!!!!!!! May have to do this a couple of times, I did. Then just remove the bolt, remove the pulley (takes a bit of persuasion and wobbling to get it off) replace with new pulley, and replace bolt. The bolt needs to be torqued up, but cant off the top of my head remember what to! I'll try find my old thread and find out. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 9, 2012 Share Posted September 9, 2012 Ive said it time and again, these pulleys have a service life, when you buy a new car dont blast 800 quid on coilovers and another grand on wheels, spend 800 quid on a crank pulley, cambelt change and new coil packs. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted September 9, 2012 Share Posted September 9, 2012 new coolant too? beings tho the rad will be taken out? thats 40 quid right there too Quote Link to comment Share on other sites More sharing options...
Noz Posted September 9, 2012 Author Share Posted September 9, 2012 Cam belt was changed and plugs. I dont have coils.... ..... thank listy :-) Quote Link to comment Share on other sites More sharing options...
