chris0132 Posted October 27, 2013 Share Posted October 27, 2013 Cheers. I think it is going to be the cheapest na-t build ever with the generosity of soo many members on here How is your car? Did you go tt in the end or na i cant remember. Awesome mate I must say you do get some very friendly people on here if you need a hand with it I'm only half hour away so can help if you need a hand I got a tt auto in the end after seeing my mate kamal's, its ok need to do a lot of work on it soon though :-/ Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 27, 2013 Author Share Posted October 27, 2013 Awesome mate I must say you do get some very friendly people on here if you need a hand with it I'm only half hour away so can help if you need a hand I got a tt auto in the end after seeing my mate kamal's, its ok need to do a lot of work on it soon though :-/ Spot on had a good play with a stock tt that my friend owns, definitely advise going bpu if you can. If you have a garage with a ramp or pit that i dont know about then you would be a legend, or can map a car Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 27, 2013 Author Share Posted October 27, 2013 just bagged an intercooler on ebay for 50quid, quite a good make these are the specs i guess: specifications: connection radius (in mm) 60,00 net size (in mm) 550 x 230 x 65 total dimension (in mm) 700 x 230 x 65 colour Alu polished maximum pressure (in psi) 45,00 charge air entry bar and plate weight (in kg) 6,16 Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 28, 2013 Author Share Posted October 28, 2013 Another very productive day of getting parts. I am not the proud owner of an AEM ecu that i am going to run rather than the map-ecu that i had so i can ensure i can alter the timing once im running boost. This is the ecu and here is a picture of the intercooler seeing as i bagged it for 50quid: AEM ECU Intercooler Quote Link to comment Share on other sites More sharing options...
chris0132 Posted October 30, 2013 Share Posted October 30, 2013 Spot on had a good play with a stock tt that my friend owns, definitely advise going bpu if you can. If you have a garage with a ramp or pit that i dont know about then you would be a legend, or can map a car Its nearly bpu apart from an fcd and to plum the 2 pipes for the boost controller its pretty much there I do know of someone with a ramp but is only free the odd Saturday but he's getting harder to get in contact with lately :-/ Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 30, 2013 Author Share Posted October 30, 2013 Ooh well that could be very handy Will have to take me for a spin in it at some point. Im hoping to have mine done by the end of November at the latest. Quote Link to comment Share on other sites More sharing options...
Iky Posted October 30, 2013 Share Posted October 30, 2013 Great work Scott it's a nice example of a Supra you have there. Quote Link to comment Share on other sites More sharing options...
chris0132 Posted October 31, 2013 Share Posted October 31, 2013 Ooh well that could be very handy Will have to take me for a spin in it at some point. Im hoping to have mine done by the end of November at the latest. Yeah man defo when I'm free one day and your not busy ill pop down Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 4, 2013 Author Share Posted November 4, 2013 Well here are the pics of the intercooler i got for 50quid Rated to 400hp so plenty for my build need. Been told that with stock na injectors 380 is probably the absolute best i could hope for. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 4, 2013 Author Share Posted November 4, 2013 Also as many of you may be aware the dam bonnet on my car has been allowing water into the top section of the spark plug chambers and causing them to short giving me a misfire. With the bad weather coming i decided to have a crack at a solution to it. First i had to dry the spark chambers out with the other halfs hairdryer Then this is a pic of the 'fix' from the outside. I have sealed the very top and angled the sides to persuade water to run down past the front of the engine. Its galvanised steel so wont rust and i dont think it affects the visuals too much, but i will make a decision on bonet after i complete my na-t build. Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted November 4, 2013 Share Posted November 4, 2013 Paint it black mate, will look much better Quote Link to comment Share on other sites More sharing options...
Steve A Posted November 4, 2013 Share Posted November 4, 2013 Paint it black mate, will look much better Agreed . I'd also paint the mesh black. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 4, 2013 Author Share Posted November 4, 2013 Paint it black mate, will look much better Yer the car is getting resprayed anyway after the conversion to na-t so i will mask the bonnet off and rattle can the the mesh and metal. Will do it tomorrow if i get chance. Will good rattle matt black take to galvanised steel or will i need to prime first as the plate isnt coming back off of the car again now. Tiger seal is mean!!!! Quote Link to comment Share on other sites More sharing options...
Homer Posted November 5, 2013 Share Posted November 5, 2013 Scott, that intercooler looks exactly the same as the one on my project car, it's tiny. Do you know what make it is? I'm thinking of changing mine but have no idea what it is, there's no stamp marks at all. Your one is the first I've seen that looks the same Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 5, 2013 Author Share Posted November 5, 2013 Scott, that intercooler looks exactly the same as the one on my project car, it's tiny. Do you know what make it is? I'm thinking of changing mine but have no idea what it is, there's no stamp marks at all. Your one is the first I've seen that looks the same Yer it's made by wiltec. Supposed to be one of those subsidiary companies that gets products debadged but not too sure if that's true. Either way everything I read about them was spot on and can't complain for the money. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 5, 2013 Author Share Posted November 5, 2013 Thanks to rob_siri i now have a lovely looking car Orange indicators finally acquired and installed! Also 'touch wood' my bonet mod has worked as the misfire isnt there today and it rained all last night Quote Link to comment Share on other sites More sharing options...
mattdavies Posted November 5, 2013 Share Posted November 5, 2013 I much prefer the Orange squares, I tinted mine so you can see them so easily and prefer them to the facelift ones !! Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 5, 2013 Author Share Posted November 5, 2013 I much prefer the Orange squares, I tinted mine so you can see them so easily and prefer them to the facelift ones !! On a red car i think they just work better. I have clear sides but the front needs to be orange imo. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 7, 2013 Author Share Posted November 7, 2013 Car been to Thor today to have the ecu fitted. All went well with the installation, however there is a misfire on the 6th cylinder when the ecu isnt bridged off. Pete is concerned that the ecu is faulty, but is going to check that the aem is passing out a signal to the injector on 6th cylinder and the stock ecu is running fine. So the car has been left overnight with them and they gave me a courtesy car for free He is going to do some work with an oscilloscope tomorrow to work out what is going on. Quote Link to comment Share on other sites More sharing options...
Slutters Posted November 7, 2013 Share Posted November 7, 2013 Keep up the good work mate! Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 8, 2013 Author Share Posted November 8, 2013 Turns out the ecu is faulty! Total nightmare but getting it sorted. Thor are excellent as are their customer service! Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 17, 2013 Author Share Posted December 17, 2013 Been over to see rich2211 today and now have my full turbo kit. Literally need to buy a flange for the oil pan and have some help drilling it and good to go. Some pics: Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 17, 2013 Share Posted December 17, 2013 Your photo taking needs some work mate Nice to meet you, and your mate. Is he a member on here? Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 17, 2013 Author Share Posted December 17, 2013 Your photo taking needs some work mate Nice to meet you, and your mate. Is he a member on here? Yer my slr is in a mode ready for the weekend and i didnt want to change it He is yer, i cant remember his user name though. We were both on the mr2 forum together before i moved over to the darkside. Quote Link to comment Share on other sites More sharing options...
scott87 Posted January 3, 2014 Author Share Posted January 3, 2014 Could anyone confirm if this is the correct fitting for the oil return. I am using an10 hose so just wanted to check the size of the http://www.ebay.co.uk/itm/AN-10-10AN-GT-T25-T28-Garrett-Turbo-Billet-Oil-Return-Flange-Bolts-Gasket-/380733077404?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58a575b79c Quote Link to comment Share on other sites More sharing options...
