Brothy Posted September 8, 2012 Share Posted September 8, 2012 Hey guys just drove 20 mile and wen i drive forward i get a grinding noise that goes grind......grind......grind but not when i reverse any ideas ?? Quote Link to comment Share on other sites More sharing options...
Geo Posted September 8, 2012 Share Posted September 8, 2012 caliper sticking maybe? Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 8, 2012 Author Share Posted September 8, 2012 Will check that, does the diff make that noise when a bearing is on its way out ? Quote Link to comment Share on other sites More sharing options...
Geo Posted September 8, 2012 Share Posted September 8, 2012 bearing is normally a droning sound? grid is something jammed on Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 8, 2012 Author Share Posted September 8, 2012 Good point, il check the pads, caliper and back plate, anything else i should check ? Quote Link to comment Share on other sites More sharing options...
Geo Posted September 8, 2012 Share Posted September 8, 2012 Good point, il check the pads, caliper and back plate, anything else i should check ? that would be a good start mate, my guess would be a sticky caliper, slider pin. only way to be sure is go give it a good once over. Quote Link to comment Share on other sites More sharing options...
listy Posted September 8, 2012 Share Posted September 8, 2012 Do you have run flats on? If one has lost air, it will do this. My old NA had runflats and I had the same problem. More likely to be caliper sticking though. Quote Link to comment Share on other sites More sharing options...
Brothy Posted September 8, 2012 Author Share Posted September 8, 2012 Sorted it, as i was freeing up the runners i noticed a stone was lodged between the pads and disc, problem solved thanks Quote Link to comment Share on other sites More sharing options...
Kaan W Posted September 8, 2012 Share Posted September 8, 2012 Sorted it, as i was freeing up the runners i noticed a stone was lodged between the pads and disc, problem solved thanks Ouch, new disks? Quote Link to comment Share on other sites More sharing options...
