JMB Posted September 8, 2012 Share Posted September 8, 2012 Hi all, I was wandering how many hp can the tiptronic box handle ?! I saw some aftermarket gear box like the Titan Motorsport, does it still able the tiptronic ? Thanks, Link to comment Share on other sites More sharing options...
Supra Gaz Posted September 8, 2012 Share Posted September 8, 2012 I believe it is the same as the standard tt auto box, so about 450 for safety and more with a gearbox cooler? Someone in the know will be along to correct me. Link to comment Share on other sites More sharing options...
thetrashcanman Posted September 8, 2012 Share Posted September 8, 2012 As Supra Gaz says, 450 is about there limit, probably no more than 500 with gearbox cooler Link to comment Share on other sites More sharing options...
JMB Posted September 8, 2012 Author Share Posted September 8, 2012 Ok thanks So I ll order the cooler (B&M or whifbitz ...) Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 8, 2012 Share Posted September 8, 2012 About 550bhp, we've run them at 600bhp without problem too. Link to comment Share on other sites More sharing options...
skyline1 Posted September 8, 2012 Share Posted September 8, 2012 What sort of cooling did you have on that Paul? Link to comment Share on other sites More sharing options...
JMB Posted September 8, 2012 Author Share Posted September 8, 2012 Do you recommand me to change the radiator + Trans cooler while installing the fmic or I can do it later ? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 9, 2012 Share Posted September 9, 2012 What sort of cooling did you have on that Paul? Just a 19 row oil cooler for the road. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 9, 2012 Share Posted September 9, 2012 Do you recommand me to change the radiator + Trans cooler while installing the fmic or I can do it later ? You can do that later if needed. Link to comment Share on other sites More sharing options...
skyline1 Posted September 9, 2012 Share Posted September 9, 2012 Just a 19 row oil cooler for the road. Cheers Paul, ill be ordering one in a month or so. Link to comment Share on other sites More sharing options...
