meth injection
matthewswinimer
hi there i will be installing a meth kit due to the fact here in novascotia we only have 91 octane premium :( when i run high boost (17-18 psi) i get detonation. just wondering if will require any tuning after installed this or will the factory ecu account for this. car is a 1994 jdm toyota supra tt 6 speed(obd1 with map sensor)
I have a meth injection kit in my car. I put 50/50 water-meth mixture in the additional tank.
When Ryan mapped it last year, we ended up not to use it. When we added the water/meth mixture, the AFR went very rich, which is normal. So you can go much leaner on the fuel, and thus run much higher boost. The big problem will come if the meth pump fails, or if the meth injector will get stuck, you will immediately blow up your engine if you floor the car.
With a water/meth setup it's recommend to have a flow sensor. Most kits come with a level sensor, but only premium kits comes with a flow sensor. This is just as important. If you have these two, then you have fail safes.
By the time you have added a decent water/meth injection kit along with all the fail safes you will need to protect the engine, you might as well buy yourself a mappable ECU and have it mapped to the lower octane fuel, however your trying to run too much boost for a std ECU anyway,
At anything over 14PSI the injector duty cycle is running at 100% so even with the correct octane fuel i suspect you will still be lacking enough fuel to run that boost.
i thought that meth was corrisove to rubbers, and aluminium and such if added directly to fuel tank.......
oh well then how come the big talk around the foums is the glorious 1.2 bar?? so confused
Yes you can run 1.2bar all right, however my statement still stands, because after a certain pressure threshold the ECU runs IDC at 100% so add the low octane fuel to the equation and of course you will get det,
What i am saying is that you will be better off with a mappable ECU to suite the fuel, rather than spend Shiite loads of cash fitting a reliable meth injection system, however you could just add the correct amount of octane booster to the fuel to bring it to 98/99 RON.
But you asked the question about meth injection, as said talk to the US guys about what to do you may get a cheap solution, but i can only give IMO sensible advice based on what you have said;)
ok thanks for the info. i think for now iam just goona get some octane boost and try it in the tank just to see if that cures it. nos brand "claims" to boost the octane by 60 points, still a little sceptical on octane boosters. and yes i plan on getting bigger injectors and aem ecu right now i cant take that big of a money shit this year.:blink:
