David P Posted September 4, 2012 Share Posted September 4, 2012 I have just bought a Chargespeed bonnet to modify and fit over my supercharger conversion and thinking to fit squirter blades instead of jets in the bonnet. Has anyone done this? Pics and parts info appreciated. Link to comment Share on other sites More sharing options...
Jamesy Posted September 4, 2012 Share Posted September 4, 2012 Must be the first post of yours i've ever seen without a million ... :rolleyes::blink: :think::think::think::think::think: Link to comment Share on other sites More sharing options...
DodgyRog Posted September 4, 2012 Share Posted September 4, 2012 I looked into it when I was getting my Jun Carbon bonnet sprayed, but ran out of time so left it as it was It is definately doable, the best option I could find were from Trucks, Merc and Scania use a clip on style, I just didn't get the time to source some to try it You would have to lengthen the original water pipe and bring it through the scuttle panel and out of the holes where the wiper arms mount to the motor mechinism Someone else had done a conversion using a verticle jet as well, I will see if I can find my thread a minute Link to comment Share on other sites More sharing options...
David P Posted September 4, 2012 Author Share Posted September 4, 2012 Must be the first post of yours i've ever seen without a million ... :rolleyes::blink: :think::think::think::think::think: Especially for you. Link to comment Share on other sites More sharing options...
David P Posted September 4, 2012 Author Share Posted September 4, 2012 I looked into it when I was getting my Jun Carbon bonnet sprayed, but ran out of time so left it as it was It is definately doable, the best option I could find were from Trucks, Merc and Scania use a clip on style, I just didn't get the time to source some to try it You would have to lengthen the original water pipe and bring it through the scuttle panel and out of the holes where the wiper arms mount to the motor mechinism Someone else had done a conversion using a verticle jet as well, I will see if I can find my thread a minute Thanks for the heads-up, I will lurk at a few lorries. Whatever system can be found and used, I think it will need to include a spoiler because even a little U.K. scoop causes the drivers wiper to lift at 70mph. Link to comment Share on other sites More sharing options...
DodgyRog Posted September 4, 2012 Share Posted September 4, 2012 Thanks for the heads-up, I will lurk at a few lorries. Whatever system can be found and used, I think it will need to include a spoiler because even a little U.K. scoop causes the drivers wiper to lift at 70mph. I can't find my thread bud, I think it might have been a discussion held in a wanted thread I put up and it was a while ago, so proberbly deleted by now Link to comment Share on other sites More sharing options...
The-Plethora Posted September 4, 2012 Share Posted September 4, 2012 I bought a few sets from stormwipers on ebay in the past. I don't believe they are as good as standard washer jets but sorts the problem and your MOT man will be happy. Link to comment Share on other sites More sharing options...
David P Posted September 4, 2012 Author Share Posted September 4, 2012 I can't find my thread bud, I think it might have been a discussion held in a wanted thread I put up and it was a while ago, so proberbly deleted by now Thanks for looking, something will turn up. I bought a few sets from stormwipers on ebay in the past. I don't believe they are as good as standard washer jets but sorts the problem and your MOT man will be happy. Whichever course I choose, it'll need to be as good or better than OE because I'm "anal" about a clean wipe. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 4, 2012 Share Posted September 4, 2012 I would instead route the squirters through the scuttle panel and have then squirting up through either the vents or small holes drilled in the scuttle. Just like the old mustangs used to have. Imi has wiper squirters on his car. They appear to work quite well, but they also look quite untidy once you open the bonnet, as it would be fiddly but not impossible to totally hide them away. Link to comment Share on other sites More sharing options...
David P Posted September 4, 2012 Author Share Posted September 4, 2012 Thanks for the input, the only wiper washer spoiler combo I have found is on a Citroen C8. http://www.ebay.co.uk/itm/290767461045?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Fortunately the weather is clean this week, maybe I will find inspiration at JAE? Link to comment Share on other sites More sharing options...
straightsix Posted September 5, 2012 Share Posted September 5, 2012 I believe the Peugeot 405s had wiper squirters? Could be a dodgy memory though! Link to comment Share on other sites More sharing options...
Benjy Posted September 5, 2012 Share Posted September 5, 2012 Personally I would have them sat in the scuttle panel just for the sale of ease and aesthetics. My 06 Vectra had them in the scuttle if you need a pair of jets that will fit. There are loads of cars that have them on the arm, but I can't for the life of me remember which ones!! Link to comment Share on other sites More sharing options...
Slam Posted September 5, 2012 Share Posted September 5, 2012 Renault Master vans have these,as me bro was looking into doing it. Link to comment Share on other sites More sharing options...
Samsar Posted September 5, 2012 Share Posted September 5, 2012 On my old Ab Flug bonnet I had mine in the scuttle panel. Link to comment Share on other sites More sharing options...
Noz Posted September 5, 2012 Share Posted September 5, 2012 That will look alot better than having piping on the wiper arms for sure. Link to comment Share on other sites More sharing options...
SPG Posted September 5, 2012 Share Posted September 5, 2012 I have the sprayers on my wiper arms, not on the Supra but on the Merc Vito van I have and they work great. Link to comment Share on other sites More sharing options...
David P Posted September 5, 2012 Author Share Posted September 5, 2012 On my old Ab Flug bonnet I had mine in the scuttle panel. http://img.tapatalk.com/d/12/09/05/uqu5apyp.jpghttp://img.tapatalk.com/d/12/09/05/yrupu4a2.jpg That's tidy, it looks like two lost ladybirds. Link to comment Share on other sites More sharing options...
neil tt Posted September 5, 2012 Share Posted September 5, 2012 I brought a pair of blades of ebay, not that great, but does the job for the mot Link to comment Share on other sites More sharing options...
supra steveo Posted September 5, 2012 Share Posted September 5, 2012 there was one of the guys i bumped into down surrey way had this done, he had an RSP aerotop that had been TT 6'ed i cant remember what his name was i remember talking to homer for alot of the time i was there so he might know who it was Link to comment Share on other sites More sharing options...
David P Posted September 6, 2012 Author Share Posted September 6, 2012 I have had this pic for sometime yet hadn't noticed before Spoilered squirter wipers Made by Mr T The Holy Grail Where's Nic when you need him, I bet he has the part numbers? Link to comment Share on other sites More sharing options...
