Hobgoblin Posted September 3, 2012 Share Posted September 3, 2012 Hi all. Am looking at getting a car for the wife, and she quite fancies the Corolla 1.8 VVT T-Sport. I have been told that these engines can suffer huge oil consumption, although there are just a few mentions of this on the net. So does anyone here have any knowledge of this, and any other telltale signs that not all is well, as I could end up buying from a dealer? Cheers Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 3, 2012 Share Posted September 3, 2012 http://www.honestjohn.co.uk/forum/post/index.htm?t=57637 found this info for you if its any help Quote Link to comment Share on other sites More sharing options...
Porky1978 Posted September 3, 2012 Share Posted September 3, 2012 It depends which year the car is. I had a 2001 Gen 7 Celica which used a lot of oil. When i looked into it i found that the earlier engines (up to 2004 iirc) were prone to piston ring issues which led Toyota to change the piston ring design. They even replaced a few engines under warranty up to a certain mileage. Quote Link to comment Share on other sites More sharing options...
David P Posted September 3, 2012 Share Posted September 3, 2012 My local Toyota Main Dealer calls them a Very Very Tired Ingine. Steer clear. Quote Link to comment Share on other sites More sharing options...
Hobgoblin Posted September 4, 2012 Author Share Posted September 4, 2012 Cheers all, food for thought Quote Link to comment Share on other sites More sharing options...
RobD Posted September 6, 2012 Share Posted September 6, 2012 My local Toyota Main Dealer calls them a Very Very Tired Ingine. Steer clear. You should correct them and inform them Engine is spelt with an E! If it uses more than 1 litre per 1000 miles Toyota sees this as to higher consumption! Anything upto 1 litre the engine is fine! Quote Link to comment Share on other sites More sharing options...
Porky1978 Posted September 6, 2012 Share Posted September 6, 2012 If it uses more than 1 litre per 1000 miles Toyota sees this as to higher consumption! Anything upto 1 litre the engine is fine! Mine used about 4 litres from Manchester to Stoke on Trent!! Quote Link to comment Share on other sites More sharing options...
RobD Posted September 6, 2012 Share Posted September 6, 2012 Mine used about 4 litres from Manchester to Stoke on Trent!! ouch! Celica's and the new shape MR2's are prone to burning a lot of oil! If a car comes in at work using more oil than it should we swap the blocks for new! Aygo's are starting to wear out engines and high mileage Prius's we've done a couple of engines now also! Quote Link to comment Share on other sites More sharing options...
Abz Posted September 6, 2012 Share Posted September 6, 2012 It depends which year the car is. I had a 2001 Gen 7 Celica which used a lot of oil. When i looked into it i found that the earlier engines (up to 2004 iirc) were prone to piston ring issues which led Toyota to change the piston ring design. They even replaced a few engines under warranty up to a certain mileage. Friend of mine said the same thing, his one died on him and he replaced it with a 1.8 VVTi engine from a 2005 Avensis. ouch! Celica's and the new shape MR2's are prone to burning a lot of oil! If a car comes in at work using more oil than it should we swap the blocks for new! Aygo's are starting to wear out engines and high mileage Prius's we've done a couple of engines now also! They just don't make them like they use to. Quote Link to comment Share on other sites More sharing options...
