Apexi Power FC and A/C issue
Kristian_Wraae
I have a strange issue with my Apexi Power FC.
I noticed that it had a high idle and I checked the sensors. I can see that the Apexi thinks the AC is on. So I check the pin 34 at E10 plug and it is ground. When checking the TSRM for the US spec Supra I can see that ground should indicate that AC is off.
So I de-pin the plug and start the car and now the Apexi thinks AC is off.
Ground Pin 34 when running causes the Apexi to detect AC on and raising the idle.
What is going on? Is the TSRM wrong?
Edited by Kristian_Wraae (see edit history)
