Digsy Posted August 31, 2012 Share Posted August 31, 2012 I just refitted one of my front wings and found I have two screws left over. The bag'o'bits that I have for the other side wing has two of these screws in it as well. I may be going senile but I cannot think where they should go. They are M6, 10mm head, and about 30mm long. Judging by the amount of corrosion, they live in a fairly nasty place. I have attached a pic before and after cleaning one of them up. Oh - and there's what looks like a self-aligning cone and shoulder on the underside of the washer face, so I guess whatever it bolts on needs to line up with something else. Link to comment Share on other sites More sharing options...
L18msy Posted August 31, 2012 Share Posted August 31, 2012 Is it for the bottom of the wing at the back. IIRC there is two bolts that go up the way into the sill, there is also a plastic spacer thing that slides onto the wing and the stepped head on the bolt fits neatly into this. Link to comment Share on other sites More sharing options...
Digsy Posted August 31, 2012 Author Share Posted August 31, 2012 (edited) I used some other bolts for there - even longer ones, with captive washers. I'll double check tomorrow that I haven't used the wrong ones. Edited August 31, 2012 by Digsy (see edit history) Link to comment Share on other sites More sharing options...
Digsy Posted September 1, 2012 Author Share Posted September 1, 2012 Is it for the bottom of the wing at the back. IIRC there is two bolts that go up the way into the sill, there is also a plastic spacer thing that slides onto the wing and the stepped head on the bolt fits neatly into this. My mistake - you're right. I've put the driver's side wing on with the wrong screws. Cheers! Link to comment Share on other sites More sharing options...
welshbuddy Posted September 1, 2012 Share Posted September 1, 2012 the state of those bolts! :O.. get new ones . Link to comment Share on other sites More sharing options...
