mixad Posted August 31, 2012 Share Posted August 31, 2012 I have had 2 coils that stooped working on my car this season. I use supersparks and boost 2.0 bar on high boost and 1,2 bar on low boost. About 2 months ago i got a new coil from Superspark. But this week I had another one stopped working. It seems o happen when i'm under high boost. I dailydrive 70% with low boost and 30% with high boost. When all was working fine I was able to boost 29 psi the whole day with no problems. When it happened last time I was pulling 3rd gear, no problems then shifted to 4th and when it hit boost it start to misfire badly. After this I can't boost at all without missfire, even on low boost. Idles perfect though, even with the "bad" coil still in car. I need to know what can cause the coils to stop working. Can I link the boost pressure and the coils malfunction? Sorry for bad english... Quote Link to comment Share on other sites More sharing options...
jimojameso Posted August 31, 2012 Share Posted August 31, 2012 I can't help with why their failing but i have heard original toyota coils are much more reliable Quote Link to comment Share on other sites More sharing options...
Carbon_Bullet Posted August 31, 2012 Share Posted August 31, 2012 I can't help with why their failing but i have heard original toyota coils are much more reliable +1 Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 31, 2012 Share Posted August 31, 2012 Buy cheap - buy twice. Quote Link to comment Share on other sites More sharing options...
absz Posted August 31, 2012 Share Posted August 31, 2012 On boost the spark duration is increased which basically means more current draw from the coil pack to jump the plug gap and maintain the spark. so a weak coil pack will fail. IF you have the coil pack failing on the same cylinder after replacement then it will be a fault with the ignitor pack (end stage) all these componets can be checked using a scope. Quote Link to comment Share on other sites More sharing options...
andz222 Posted September 8, 2012 Share Posted September 8, 2012 I can't help with why their failing but i have heard original toyota coils are much more reliable agree go with stock coils Quote Link to comment Share on other sites More sharing options...
