HadeS Posted August 30, 2012 Share Posted August 30, 2012 Hello everyone I'm looking for some information about putting oil squirters in to NA block. I know it is doable but is it worth to fit them? I'll be looking for something close to 600bhp. Would you recommend fitting them? Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 31, 2012 Share Posted August 31, 2012 The info I have says that the cut off point for needing piston cooling jets is when the engine brake power divided by the piston area is greater than 3.5MW / m^2 For an 86mm bore the total piston area is 0.035m^2 600bhp is 447kW So power / area = 12.8MW/m^2 ....so yes, I would say you need them Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 31, 2012 Share Posted August 31, 2012 chris wilson does these,but as your in poland it might not be so cheap due to delivery Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 31, 2012 Share Posted August 31, 2012 Are the TT and NA oil pumps different? Oil squirters consume a LOT of oil, and they rob it from the main gallery, so it will globally drop oil pressure around the engine. If the NA oil pump isn't specced to feed oil squirters then you might cause a crankshaft lubrication problem. Quote Link to comment Share on other sites More sharing options...
HadeS Posted September 2, 2012 Author Share Posted September 2, 2012 Are the TT and NA oil pumps different? Oil squirters consume a LOT of oil, and they rob it from the main gallery, so it will globally drop oil pressure around the engine. If the NA oil pump isn't specced to feed oil squirters then you might cause a crankshaft lubrication problem. Yes I know how they work and good oil pump is required to make sure there is good lubrication. Has any one got some pictures from instalation? Quote Link to comment Share on other sites More sharing options...
Noz Posted September 2, 2012 Share Posted September 2, 2012 It's been proven that the engine doesn't always require oil squirters. Jekyl runs 500hp and hasn't had any problems. The limitation of that calculation states 400bhp is the limit before squirters are needed. There are many people running just over this, but Jekyl is the first one that comes to mind. His engine (and his last one) running 500 gives 4.3MW/m² which is over the 3.5 recommended. Obviously there is a number of other areas that can affect performance engine wear etc. There are other considerations such as compression ratio and I think without taking that into account you can't reliably state if they need to be used or not. There is NA-T runners pushing 700 without squirters, and claim they haven't needed them or at least haven't failed because of them. I looked into this when I was aiming for more than 400hp and found lots of US information on other forums as it's not hugely done here. It will probably be cheaper to use uprated pistons if you want peace of mind. Quote Link to comment Share on other sites More sharing options...
HadeS Posted September 2, 2012 Author Share Posted September 2, 2012 Well with my setup I may hit more than 600bhp. I think if the engine is in bits I'll fit them. Quote Link to comment Share on other sites More sharing options...
V8KILR Posted September 3, 2012 Share Posted September 3, 2012 (edited) If you are running stock NA or TT pistons then it would be a very good idea. If running forged pistons then they are not necessary until you get to very high hp. To do this you need the TT oil pump and an oil feed to the gallery the oil squirters get their oil from. On an NA block this gallery is dry, so you can either get oil to it by: 1. drilling across the front of the block to feed the front of this gallery from the oil gallery on the intake side. This is a PITA, or 2. drill a hole in the turbo side of the block where one of the oil feeds to the TT normally is as this is just a blank on the NA engine block. Then feed oil in to this hole from a splitter where your oil filter or aftermarket oil cooler is. I went with option #2. Edited September 3, 2012 by V8KILR (see edit history) Quote Link to comment Share on other sites More sharing options...
