welshbuddy Posted August 30, 2012 Share Posted August 30, 2012 Hey guys I have just gone single Turbo, what I need to know is do I need a wideband to make sure its running right? If so opinions on what models and such. Cheers Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 30, 2012 Share Posted August 30, 2012 Yes its preferable to run a wide-band, but if its been mapped correctly you shouldn't have any problems. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 30, 2012 Author Share Posted August 30, 2012 am i right in thinking. The afr gauge with the sensor is a ....wideband? Quote Link to comment Share on other sites More sharing options...
David P Posted August 30, 2012 Share Posted August 30, 2012 Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 30, 2012 Author Share Posted August 30, 2012 ???? tard. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 30, 2012 Share Posted August 30, 2012 am i right in thinking. The afr gauge with the sensor is a ....wideband? Well yes! popular makes are AEM UEGO, and Innovate LC-1, they can also be connected to aftermarket ECUs for better control, which ECU are you using with your single set up? Quote Link to comment Share on other sites More sharing options...
David P Posted August 30, 2012 Share Posted August 30, 2012 ???? tard. Excuse me I couldn't resist, O.E. O2 sensor is Narrow Band. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 30, 2012 Author Share Posted August 30, 2012 Well yes! popular makes are AEM UEGO, and Innovate LC-1, they can also be connected to aftermarket ECUs for better control, which ECU are you using with your single set up? thankyou mate, i do have a afr gauge/with sensor. (so i think thats a wideband). With the 1jz, as its runs parallel (turbos) it can run it on stock ecu. (littlenum is also doing this). but later date i will buy probs hks f con gold Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 30, 2012 Share Posted August 30, 2012 With the 1jz, as its runs parallel (turbos) it can run it (a single) on stock ecu. Pedro flippin' LOVES this little bit of information! Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 30, 2012 Author Share Posted August 30, 2012 thought you might , mines run perfect with stock ecu. we just want to make sure if its running lean or not. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 30, 2012 Share Posted August 30, 2012 thankyou mate, i do have a afr gauge/with sensor. (so i think thats a wideband). With the 1jz, as its runs parallel (turbos) it can run it on stock ecu. (littlenum is also doing this). but later date i will buy probs hks f con gold Be careful some of the cheaper AFR gauges are just narrow-band, which is practically useless, as for the ECU running things fine, well unless the new turbo is producing exactly the same flow rate and pressure as the old setup, then it will almost certainly be running lean, so i would get a wide-band sensor fitted ASAP and don't push it until you know for sure. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 30, 2012 Author Share Posted August 30, 2012 mates checking it for me tomorrow, im sure its the wideband as i bought 5 gauges with all sensors. cheers for the help mate. Quote Link to comment Share on other sites More sharing options...
