matthewswinimer Posted August 29, 2012 Share Posted August 29, 2012 hi there, i just installed my bcc that i purchased from the suprastore(greddy replacement) and i was wondering what the correct voltage to set it at is?? ive read about 2 different numbers bouncing around...4.3 and also 4.45. just wondering which number is correct. my car is a 1994 supra tt. obd 1 with map sensor. currently installing everything for bpu. Link to comment Share on other sites More sharing options...
Ian C Posted August 30, 2012 Share Posted August 30, 2012 hi there, i just installed my bcc that i purchased from the suprastore(greddy replacement) and i was wondering what the correct voltage to set it at is?? ive read about 2 different numbers bouncing around...4.3 and also 4.45. just wondering which number is correct. my car is a 1994 supra tt. obd 1 with map sensor. currently installing everything for bpu. 4.40 volts should see you right Link to comment Share on other sites More sharing options...
matthewswinimer Posted August 30, 2012 Author Share Posted August 30, 2012 4.40 volts should see you right ok thanks. on a seperate note, iam want to diasble the speed limiter for drag racing, just cant justify spending the money for a scc, i was wondering what will happen if a take and cut the pink speed sensor wire going to the ecu and install a switch, will it have any adverse effects other then speedo not working. like i said thats not a big deal for me when drag racing. Link to comment Share on other sites More sharing options...
Ian C Posted August 30, 2012 Share Posted August 30, 2012 Sympathetically disconnect it and find out It might cock up the autobox, the speed sensitive power steering, and throw a fault code. Link to comment Share on other sites More sharing options...
matthewswinimer Posted August 31, 2012 Author Share Posted August 31, 2012 Sympathetically disconnect it and find out It might cock up the autobox, the speed sensitive power steering, and throw a fault code. my car is a 6 speed. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 31, 2012 Share Posted August 31, 2012 4.3 i use Link to comment Share on other sites More sharing options...
