SRD twin fans fitted, can Syvecs control them?
tooquicktostop
Dave has been manic fitting parts ready for this Friday when the car goes into Garage Whifbitz for the single turbo conversion, Dave has fitted the SRD twin fan kit which he tells me performs really well, it is on a switch right now on the dash, so on or off, can the syvecs control the fans if is so do I need to do anything (buy parts) in advance of Ryan getting the car for mapping
The syvecs is a negative output so put that through a relay to give a 12v and connect it to your output from the switch. You can leave the switch there as an overide as well.
The syvecs can them be programed to run the fans, I usually have them come on around 94-95 and go off at 89-90.
The fans should be fused seperatly and have a relay each.
Little off topic but what turbo setup you going for mate and what power are you aiming for?
