Max Limit of 850cc Injector?
a98pmalcolm
Well 85% should be your max duty cycle...
I don't really believe in that rule of thumb any more, I think that's from way back in the early days of EFI. I've never heard of an injector failing apart from being gummed up, and all the BPU Supras out there run 100% duty once they get over 1bar :)
I agree with Ian about injectors being able to run to 100% with no problems so long as they are not at 100% for an extended period of time (as they can overheat) which is very unlikely for most people. Mine are at about 90% at the moment.
Poached into tech
Very good. :)
Also depends on your base pressure and fuel being used.
You should first work out your goal and then size them appropriately.
My Supra injector calculator allows for base pressure and fuel type as well. :)
Your calculator doesn't take into account a higher rev limit, does it? I've just had a play and it's accurate for my car if I only went to 6800rpm, not 7200 :)
The calculator use WHP and AF ratio as the two main inputs and what RPM this power is made at is ignored by the calculator. Thinking about it, you make a very good point that at higher RPM, there will be more internal friction inside the engine (mainly from the pistons) so that the BHP figure would be higher then it would be for the same WHP that was made at lower RPM. As it is BHP that is made from the fuel (not WHP), I will need to adjust the calculator to take this in to account.
Thanks for pointing this out. :) Are you able to send me some data logging (dyno type, injector ms, rpm and whp) that shows your increasing fuel usage with rpm?
I'll have a go at incorporating RPM in to the calculator this weekend. :)
Edited by V8KILR (see edit history)
The reason I mentioned rev limits isn't because of friction or anything, it's just that the max duty cycle becomes shorter as the revs get faster.
For a given amount of boost, you need pretty much the same amount of fuel per ignition event no matter what the revs are (within engine breathing abilities of course). So a cylinderful of air at 21psi boost needs the same amount of injector duration at 5500rpm as it does at 6500rpm and 7200rpm. But the window of opportunity to deliver that duration is much shorter at 7200rpm than at 5500rpm. You get 20ms between ignition events at 5500rpm, and only 16ms at 7200rpm. If you need 16ms of duration per ignition event with your boost/injector/fuel pressure setup, that's 100% duty at the top end but only 80% duty at 5500rpm.
Yes, the power goes up as you go up the rev range, but that's only because you're doing more ignition events per second, the power increase has nothing to do with boost pressure. So your target maximum revs are very important to sizing your injectors, a small increase in revs can quickly make injectors run out of time to deliver the fuel :)
Putting the numbers into your calculator, it does make sense if you allow for a 6800rpm limit. My rwhp at 21psi at 85% duty gives me 720cc injectors, which is all correct. That's 15.6ms duration, so upping it to 7200rpm mean 94% duty which is roughly what I'm seeing.
I don't think the injector ms vs rpm makes any difference, as when you are at 100% injector duty cycle, then its still 100% duty cycle no matter what the rpm, so you never run out of time to deliver the fuel. All that matters is if the quantity of fuel delivered at 100% is sufficient for the maximum fuel requirements of the engine, irrespective of whether that maximum fuel requirement of the engine is at 6800rpm, 8000rpm or 10000rpm.
Friction losses however do play a big part at high rpm as the friction losses increase at about 2 ^ 2.84, if you double the rpm. i.e Doubling rpm will increase friction losses by 7.16 times. Because my calculator uses whp and the engine is producing bhp and using fuel for bhp, then the engine losses do make a big difference to my calculator, as the extra fuel required to cover the extra friction losses increases very quickly at high rpm.
Have a read of the link below (this is page 2 but you may need to read page 1 as well) where I was educated on how much friction losses do occur inside our engines. :)
http://www.supraforums.com.au/forum/a80-mkiv-discussion/79385-12-injectors-vs-6-injectors-400rwkw-na-2.html
