add heywood Posted August 28, 2012 Share Posted August 28, 2012 Started cleaning the engine bay for the shoot tomorrow, took the air feed off the turbo and noticed a very clean looking hose connector underneath, you can see it in the photo's... First thing is what is it and should there be a pipe to connect it to...? As you can see i have an oil leak that needs fixing... Could this be the culprit? Link to comment Share on other sites More sharing options...
add heywood Posted August 28, 2012 Author Share Posted August 28, 2012 Had to upload pictures on the ipad so i apologise for the rubbish quality. It is inder the metal bit the viscous fan attaches to Link to comment Share on other sites More sharing options...
hodge Posted August 28, 2012 Share Posted August 28, 2012 That's a drain plug for the water pump. It's a saftey feature on the pump incase too much pressure builds up in the system it pops the seal inside the pipe and let's the fluid out, instead of cracking the head or block. Link to comment Share on other sites More sharing options...
add heywood Posted August 28, 2012 Author Share Posted August 28, 2012 Cheers hodge Link to comment Share on other sites More sharing options...
Iky Posted August 28, 2012 Share Posted August 28, 2012 Probably best keep a short length of hose on it. Incase the water pump does screw up. This way it will avoid it going all over the alternator and killing that. Link to comment Share on other sites More sharing options...
Swampy442 Posted August 28, 2012 Share Posted August 28, 2012 Hodge is sort of right, its a dry drain for the water pump. Should the bearing seal fail coolant will leak out as an indication something is wrong. Link to comment Share on other sites More sharing options...
Digsy Posted August 28, 2012 Share Posted August 28, 2012 Hodge is sort of right, its a dry drain for the water pump. Should the bearing seal fail coolant will leak out as an indication something is wrong. Link to comment Share on other sites More sharing options...
