Geo Posted August 28, 2012 Share Posted August 28, 2012 Right, So i normally use my Local Toyota for small bits and bobs for the car. So i sent the guy a list of what im needing to replace some parts i want NEW!!! Cam cover bolts 90105-06166 (You'll need 12) = £9.18 inc vat Cam cover nut 90179-06288 (You'll need 4) = £3.06 inc vat Cam cover washer 90210-07001 (You'll need 16) = £34.13 inc vat Cam cover gasket (Inlet) 11213-46020 = £11.60 inc vat Cam cover gasket (Exhaust) 11214-46011 = £11.60 inc vat Coil pack clip 90980-11246 6 off = £34.62 inc vat Cam breather hose 12263-46010 1 off = £10.63 inc vat Cam breather hose 12264-46010 1 off = £9.23 inc vat Sealant - For Oil Pan/Cam Shaft sealing Toyota's Black FIPG old part number was 00295-00102, but was superseded by new part number 00295-00103 - part number has changed again and it is now - 08826-80010 = £70.94 inc vat Fuel Filter - 23300-49195 = £34.99 inc vat Upper Rad Pipe OEM - 16571-46150, 2xclips 90467-37005 = £24.86 inc vat Serpintine Belt - 90916-02310 = £41.84 inc vat O2 sensor(4 wire) DOX-0228 (no idea what the Toyota part is? - Toyota part number is 89465-19635) = £ 145.00 inc vat Just waiting on Steve Manley getting back to me, but im gona email Paul see what he can come up with?? Quote Link to comment Share on other sites More sharing options...
Westy Posted August 28, 2012 Share Posted August 28, 2012 Wow that adds up fast! Quote Link to comment Share on other sites More sharing options...
Littler Posted August 28, 2012 Share Posted August 28, 2012 (edited) Assuming my prefacelift TT O2 sensor is the same as a facelift I got mine from rockauto.com for £63 delivered, believe Martin fitted one to Havard's VVTI as well so may save you some cash there EDIT: found the part number off my invoice its denso 2344514 and I've had no issues 4000 miles down the line Edited August 28, 2012 by Littler (see edit history) Quote Link to comment Share on other sites More sharing options...
Geo Posted August 28, 2012 Author Share Posted August 28, 2012 Wow that adds up fast! Tell me about it. Assuming my prefacelift TT O2 sensor is the same as a facelift I got mine from rockauto.com for £63 delivered, believe Martin fitted one to Havard's VVTI as well so may save you some cash there I can get then o2 sensor delivered for £41, just want to see what prices toyota comes in at? Quote Link to comment Share on other sites More sharing options...
Littler Posted August 28, 2012 Share Posted August 28, 2012 I can get then o2 sensor delivered for £41, just want to see what prices toyota comes in at? Ah fair enough lol Quote Link to comment Share on other sites More sharing options...
Style Posted August 28, 2012 Share Posted August 28, 2012 After reading that thread title, I thought this was gonna be about you buying some mega track spec bucket seats! Glad i was wrong That does add up fairly quickly though, I always thought going to Toyota direct was the most expensive option every time no? I'm sure Paul can knock a few bucks offa that! Quote Link to comment Share on other sites More sharing options...
Kirk Posted August 28, 2012 Share Posted August 28, 2012 You can save yourself a fortune on the sealant. http://www.ebay.co.uk/itm/Loctite-5699-Premium-Grey-Silicone-Gasket-Maker-Sealant-JDM-Japanese-Engines-/270940232164?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f154bd9e4 This is more or less the same stuff and all I ever use for sealing purpose. You can also use something like blue hylomar which is roughly the same price. Again you can save some ££ by getting your aux belt from a local motor factors our online. http://www.ebay.co.uk/itm/GATES-6pk-1938-6pk1938-Micro-V-Ribbed-Fan-Auxiliary-Alternator-DriveBelt-/350510886660?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item519c13af04 Quote Link to comment Share on other sites More sharing options...
Geo Posted August 28, 2012 Author Share Posted August 28, 2012 You can save yourself a fortune on the sealant. http://www.ebay.co.uk/itm/Loctite-5699-Premium-Grey-Silicone-Gasket-Maker-Sealant-JDM-Japanese-Engines-/270940232164?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f154bd9e4 This is more or less the same stuff and all I ever use for sealing purpose. You can also use something like blue hylomar which is roughly the same price. Again you can save some ££ by getting your aux belt from a local motor factors our online. http://www.ebay.co.uk/itm/GATES-6pk-1938-6pk1938-Micro-V-Ribbed-Fan-Auxiliary-Alternator-DriveBelt-/350510886660?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item519c13af04 cool mate, i'll get some of those ordered up. Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 28, 2012 Share Posted August 28, 2012 You can save yourself a fortune on the sealant. http://www.ebay.co.uk/itm/Loctite-5699-Premium-Grey-Silicone-Gasket-Maker-Sealant-JDM-Japanese-Engines-/270940232164?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f154bd9e4 This is more or less the same stuff and all I ever use for sealing purpose. You can also use something like blue hylomar which is roughly the same price. I would recommend Loctite 5900 for sealing a large surface like an oil pan. It has better compatability with gasoline (which will be present in small quantities in engine oil) and also leeches less free silicone into the oil, reducing the risk of damge to the O2 sensor. It is also contains a thickener to make it more suitable for application by hand (5910 is the same product but designed for application by robot). Although the manufacturers used to make all sorts of claims for blue Hylomar I wouldn't use it on an application that was not 100% smooth and flat and wasn't backed up by some other kind of gasket. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 28, 2012 Share Posted August 28, 2012 Why do you need new cam cover nuts and bolts ? If you do try a local fasteners, general stuff is pennies not pounds Quote Link to comment Share on other sites More sharing options...
Geo Posted August 28, 2012 Author Share Posted August 28, 2012 Why do you need new cam cover nuts and bolts ? If you do try a local fasteners, general stuff is pennies not pounds got a small weep coming from the rear RHS cam cover, its the gasket. So im going to replace the whole lot, Yeah i might very do, i just want to see the price difference between the 3? Quote Link to comment Share on other sites More sharing options...
Kirk Posted August 28, 2012 Share Posted August 28, 2012 I would recommend Loctite 5900 for sealing a large surface like an oil pan. It has better compatability with gasoline (which will be present in small quantities in engine oil) and also leeches less free silicone into the oil, reducing the risk of damge to the O2 sensor. It is also contains a thickener to make it more suitable for application by hand (5910 is the same product but designed for application by robot). Although the manufacturers used to make all sorts of claims for blue Hylomar I wouldn't use it on an application that was not 100% smooth and flat and wasn't backed up by some other kind of gasket. To be fair Digsy he's only using a bit on the front of the cam covers so I can't see them causing a problem as it is only a small amount needed. I have used 5699 before on an autobox sump with no issues either but thanks for the recommendation. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 28, 2012 Share Posted August 28, 2012 got a small weep coming from the rear RHS cam cover, its the gasket. So im going to replace the whole lot, Yeah i might very do, i just want to see the price difference between the 3? There shouldn't be anything wrong with the nuts and bolts and overkill replacing them to be honest Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 28, 2012 Share Posted August 28, 2012 To be fair Digsy he's only using a bit on the front of the cam covers so I can't see them causing a problem as it is only a small amount needed. I have used 5699 before on an autobox sump with no issues either but thanks for the recommendation. No worries You could probably use almost any RTV if its just for the bit near the cam covers, and as you say the other contamination issues would not be relevant on a transmission. Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted August 28, 2012 Share Posted August 28, 2012 Interesting to see Toyota dealer price variations! I got those two breathers for slightly less. The fuel filter and coil pack prices sound slightly cheaper than Paul, but for such little difference I'd personally be using Paul for these Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 28, 2012 Share Posted August 28, 2012 (edited) Are the O2 sensors the same as the ones from my UK GS300 (NA)? If so, I have them ready to go. I can take photos if required. Edited August 30, 2012 by SteveR SG -> GS typo (see edit history) Quote Link to comment Share on other sites More sharing options...
Geo Posted August 29, 2012 Author Share Posted August 29, 2012 Are the O2 sensors the same as the ones from my UK SG300 (NA)? If so, I have them ready to go. I can take photos if required. no idea mate, show me a pic? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted August 29, 2012 Share Posted August 29, 2012 I like what your doing with your project Geo, ie putting up part numbers AND prices its good for people like me who take notes and save links that other people post for cheaper items. £70odd for sealent is a joke. Keep it up mate. Quote Link to comment Share on other sites More sharing options...
tomgeer Posted August 30, 2012 Share Posted August 30, 2012 Aaron at Steven Eagell Toyota in Milton Keynes is good for supra parts, I usually go to him, postage always reasonable too, definitely worth sending him an email : [email protected] Quote Link to comment Share on other sites More sharing options...
SteveR Posted September 1, 2012 Share Posted September 1, 2012 no idea mate, show me a pic? O2 sensors from my Lexus - sorry for the delay. Quote Link to comment Share on other sites More sharing options...
Geo Posted September 1, 2012 Author Share Posted September 1, 2012 O2 sensors from my Lexus - sorry for the delay. [ATTACH=CONFIG]157047[/ATTACH] steve count if they are 4 or 2 wire? Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 1, 2012 Share Posted September 1, 2012 There both 4 pin by the looks of it but only the one with flange is the correct fitment. Quote Link to comment Share on other sites More sharing options...
SteveR Posted September 1, 2012 Share Posted September 1, 2012 Just checked - both have 4 pins - photo of the one with a flange. Quote Link to comment Share on other sites More sharing options...
