T14PPA Posted August 27, 2012 Share Posted August 27, 2012 hi, ive just purchased a cheap gt45 turbo kit and im wondering what size injectors people would recomend? im looking to run around 600bhp. Its going to be mapped by ryan on my hks fcon gold. Also will i need to upgrade my 255 walbro pump? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 27, 2012 Share Posted August 27, 2012 for 600 BHP you will need a 450 pump and at least 650cc injectors Quote Link to comment Share on other sites More sharing options...
Kaan W Posted August 27, 2012 Share Posted August 27, 2012 I have 1000cc IDs and a bosch 044 fuel pump with around 600bhp. Runs great. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted August 28, 2012 Author Share Posted August 28, 2012 I was thinking 850cc and 044 bosch fuel pump. Are these to big? Quote Link to comment Share on other sites More sharing options...
Wez Posted August 28, 2012 Share Posted August 28, 2012 I was thinking 850cc and 044 bosch fuel pump. Are these to big? I would say that's a good combo for your goal Quote Link to comment Share on other sites More sharing options...
T14PPA Posted August 28, 2012 Author Share Posted August 28, 2012 Cheers mate Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 28, 2012 Share Posted August 28, 2012 650cc would be cutting it fine i think at 600bhp, 750cc minimum i would say always room for bigger power, im running a walbro 400 lph flows more then a bosch and so much easier to fit, it goes straight on the bracket like the 255 Quote Link to comment Share on other sites More sharing options...
hodge Posted August 28, 2012 Share Posted August 28, 2012 You'll need 1000cc injectors, to be safe and a Bosch 044 pump with -8AN feed line. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted August 28, 2012 Share Posted August 28, 2012 how do you know, if there drop in injectors? as i need 750cc soon. Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 28, 2012 Share Posted August 28, 2012 depends on what rail you have stock is side entry,alot of after market are top feed the injectors can be high impendance jspec or low impedance uk. that should help Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted August 28, 2012 Share Posted August 28, 2012 650cc would be cutting it fine i think at 600bhp, 750cc minimum i would say always room for bigger power, im running a walbro 400 lph flows more then a bosch and so much easier to fit, it goes straight on the bracket like the 255 sorry to thread jack but how was the 400 to fit? does it need anymore wiring as the stock wiring looked a bit thin when i put the 255 in. Does it operate fine with the stock fuel pump ecu? I was planning an 044 eventually but I've heard this 400 walbro mentioned on a few forums now. Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 28, 2012 Share Posted August 28, 2012 sorry to thread jack but how was the 400 to fit? does it need anymore wiring as the stock wiring looked a bit thin when i put the 255 in. Does it operate fine with the stock fuel pump ecu? I was planning an 044 eventually but I've heard this 400 walbro mentioned on a few forums now. it fits straight on the stock hanger tight but fits with no modification, now the interesting bit mine didnt work with the stock ecu but that might have been the problem with mine in the first place, i had to do the 12v relay mod but have since found a poorly isulated dead ended fuel pump cut off divice of some sort may have caused the hole issue. so all in all even if having to do the 12v mod its still a hell of alot easier the the 044 just in case you need it http://mkivsupra.net/vbb/showthread.php?272714-12v-mod-will-this-work Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted August 28, 2012 Share Posted August 28, 2012 thanks for the link, will have a read as it certainly seems easier to fit and is a dedicated in tank item which makes me feel a bit more comfortable than the 044. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted August 28, 2012 Share Posted August 28, 2012 I would go for ID1000, to be on the safe side in case you want more power. Quote Link to comment Share on other sites More sharing options...
V8KILR Posted August 30, 2012 Share Posted August 30, 2012 Check out the Supra injector calculator on my website. http://mkiv.supras.org.nz/injectors.htm Quote Link to comment Share on other sites More sharing options...
