mattdavies Posted August 28, 2012 Share Posted August 28, 2012 No that's my wheels 18x10 et20 Quote Link to comment Share on other sites More sharing options...
alex2jz Posted August 28, 2012 Share Posted August 28, 2012 No that's my wheels 18x10 et20 That's about the same as 10.5J and ET24. They would only EXTEND an extra 2mm compared to yours. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted August 28, 2012 Author Share Posted August 28, 2012 Do you have any closer pictures of the Rear of your supra with yours fitted mate to give me an idea? More the better if you can Also are you on a full roll of the rear arch then? and are you on stock suspension too? Quote Link to comment Share on other sites More sharing options...
mattdavies Posted August 28, 2012 Share Posted August 28, 2012 http://s203.photobucket.com/albums/aa284/mattdavies1988/?action=view¤t=IMG00559-20120509-1700.jpg&mediafilter=noflash This picture is the only other picture I have, show the scrubage I had with a dodgy shock on stock suspension. This has no arch rolling , with the arches rolled prob have another 10mm Quote Link to comment Share on other sites More sharing options...
alex2jz Posted August 29, 2012 Share Posted August 29, 2012 Fitting is one thing but handling and bearing wear are other things when having low offset wheels... I personally wouldn't go under +35 on a Supra. There was a nice thread on SF regarding wheel setups and there was this wheel guru there that always said don't go under +45, get a wider wheel, you'll just put more stress on the bearings and won't be able to run a decent size tire. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 2, 2012 Author Share Posted September 2, 2012 Ok instead of making a new thread what about this spec- -18x11 et35 Quote Link to comment Share on other sites More sharing options...
mattdavies Posted September 2, 2012 Share Posted September 2, 2012 You should use willtheyfit.com And it will tell you everything you need to know Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted September 2, 2012 Author Share Posted September 2, 2012 Yeah cheers bud just used the spec Nic posted as a guide and answered my own question thanks mate Quote Link to comment Share on other sites More sharing options...
Nic Posted September 2, 2012 Share Posted September 2, 2012 Ok instead of making a new thread what about this spec- -18x11 et35 They'll stick out around 10mm past the stock wheel arches (10mm more than the pic I posted earlier in the thread). As a rough guide the wheels I had on my car (18x9 +32 & 18x10 +32) were pretty much flush with the stock wheel arches. If you want to know how a certain wheel width and offset will fit, go here http://www.1010tires.com/WheelOffsetCalculator.asp and enter the above wheel details and then input the sizes you want to compare. Quote Link to comment Share on other sites More sharing options...
