Snap off steering wheel
_Shane_
Going to fit one of these to my supra and was wondering how straight forward it is
Currently my steering wheel setup looks like
If i purchase a snap off steering wheel is it just a matter of me removing the existing boss that you see fitted in the above pic, then fit the new thinner boss and thats it job done or is there anything else i must do?
I have a driftworks one in mine and I love it. Very easy to fit too only takes about 20min or so. Make sure you get a quality one as I made the mistake of buying an eBay one at first and it was complete garbage, didn't even bother fitting it.
the boss kit above in my pic that came fitted in the car, do i remove that and then replace that with the snap off kit?
OR does the snap off hub go onto the existing hub you see in the above pic? Thats where im a bit confused?
Thanks lads
Thanks lads
My driftworks one fitted onto my existing boss. Hope this helps
Never understood the need to be able to remove your steering wheel. Unless you have a hideously obstructive roll cage or a disability.
Superb theft deterant! I had one on a previous & as mentioned it does help on insurance. :)
anyone know if i can remove the hub as per pic above and then fit my snap off kit ??? or must the snap off kit attach to the existing hub ?
Only reason im asking / need to know this is i have a dished steering wheel at the moment and it comes out a nice bit than a normal flushed wheel
Thanks
What snap off boss do you have? On the Driftworks one it brings the wheel about 40mm nearer to you.
You may be able to find std boss that is shorter than the one already fitted, I think JP had a shorter one on his car.
Unless you get a weld on boss any removable ones I have seen would attach to your current boss and not replace it.
Hope that helps
