_Shane_ Posted August 27, 2012 Share Posted August 27, 2012 Going to fit one of these to my supra and was wondering how straight forward it is Currently my steering wheel setup looks like If i purchase a snap off steering wheel is it just a matter of me removing the existing boss that you see fitted in the above pic, then fit the new thinner boss and thats it job done or is there anything else i must do? Link to comment Share on other sites More sharing options...
Guigsy Posted August 27, 2012 Share Posted August 27, 2012 Never understood the need to be able to remove your steering wheel. Unless you have a hideously obstructive roll cage or a disability. Link to comment Share on other sites More sharing options...
JakeG Posted August 27, 2012 Share Posted August 27, 2012 (edited) when i fitted one and informed my insurance it lowered it by £50, good added safety feature for minimum money imo Edited August 27, 2012 by JakeG (see edit history) Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 27, 2012 Share Posted August 27, 2012 I can't get in or out of the car without taking mine off!! Link to comment Share on other sites More sharing options...
Supra Gaz Posted August 27, 2012 Share Posted August 27, 2012 I have one, helps me get in and out of my bucket seat, also .akes me feel like im in a racing car!! It did help insurance too. Link to comment Share on other sites More sharing options...
abtin90 Posted August 27, 2012 Share Posted August 27, 2012 I have a driftworks one in mine and I love it. Very easy to fit too only takes about 20min or so. Make sure you get a quality one as I made the mistake of buying an eBay one at first and it was complete garbage, didn't even bother fitting it. Link to comment Share on other sites More sharing options...
_Shane_ Posted August 27, 2012 Author Share Posted August 27, 2012 the boss kit above in my pic that came fitted in the car, do i remove that and then replace that with the snap off kit? OR does the snap off hub go onto the existing hub you see in the above pic? Thats where im a bit confused? Thanks lads Link to comment Share on other sites More sharing options...
abtin90 Posted August 27, 2012 Share Posted August 27, 2012 the boss kit above in my pic that came fitted in the car, do i remove that and then replace that with the snap off kit? OR does the snap off hub go onto the existing hub you see in the above pic? Thats where im a bit confused? Thanks lads My driftworks one fitted onto my existing boss. Hope this helps Link to comment Share on other sites More sharing options...
abtin90 Posted August 27, 2012 Share Posted August 27, 2012 By the way I'm loving the interior of your car, looks great Link to comment Share on other sites More sharing options...
Abz Posted August 27, 2012 Share Posted August 27, 2012 Never understood the need to be able to remove your steering wheel. Unless you have a hideously obstructive roll cage or a disability. Superb theft deterant! I had one on a previous & as mentioned it does help on insurance. Link to comment Share on other sites More sharing options...
abtin90 Posted August 27, 2012 Share Posted August 27, 2012 Didn't know it makes such a difference on insurance, going to have to call mine today Link to comment Share on other sites More sharing options...
Luxluc Posted August 27, 2012 Share Posted August 27, 2012 I can't get in or out of the car without taking mine off!! Why that? Do you have a full cage in your Supra??? Link to comment Share on other sites More sharing options...
tkddav3 Posted August 27, 2012 Share Posted August 27, 2012 got one fitted to mine too, might give the insurer a ring to see if it helps Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 27, 2012 Share Posted August 27, 2012 Why that? Do you have a full cage in your Supra??? Fixed bucket seat, column extended 40mm and a pot belly! Link to comment Share on other sites More sharing options...
abtin90 Posted August 27, 2012 Share Posted August 27, 2012 Fixed bucket seat' date=' column extended 40mm and a pot belly![/quote'] Link to comment Share on other sites More sharing options...
_Shane_ Posted August 27, 2012 Author Share Posted August 27, 2012 anyone know if i can remove the hub as per pic above and then fit my snap off kit ??? or must the snap off kit attach to the existing hub ? Only reason im asking / need to know this is i have a dished steering wheel at the moment and it comes out a nice bit than a normal flushed wheel Thanks Link to comment Share on other sites More sharing options...
sideexitsupra Posted August 27, 2012 Share Posted August 27, 2012 What snap off boss do you have? On the Driftworks one it brings the wheel about 40mm nearer to you. You may be able to find std boss that is shorter than the one already fitted, I think JP had a shorter one on his car. Unless you get a weld on boss any removable ones I have seen would attach to your current boss and not replace it. Hope that helps Link to comment Share on other sites More sharing options...
Luxluc Posted August 27, 2012 Share Posted August 27, 2012 Fixed bucket seat' date=' column extended 40mm and a pot belly![/quote'] Link to comment Share on other sites More sharing options...
