D8MOA Posted August 25, 2012 Share Posted August 25, 2012 just bite the bullet and get a TT Quote Link to comment Share on other sites More sharing options...
Noz Posted August 25, 2012 Share Posted August 25, 2012 Lovely, think I'm going to go 1UZ route instead now actually, and Geo, i think N/A engines are even cheaper than that tbh, closer to £200 I think I paid £75 for mine. 300quid would be a rip off! Quote Link to comment Share on other sites More sharing options...
Morpheus Posted August 25, 2012 Share Posted August 25, 2012 Morpheus might appreciate that one? Wow, you are showing your age Dave! I'd heard of him but had to look him up as I'm only a spring chicken of 43. I used to own a GMC Jimmy though, as it happens. Hence the Typhoon in the garage. Quote Link to comment Share on other sites More sharing options...
David P Posted August 25, 2012 Share Posted August 25, 2012 (edited) Wow, you are showing your age Dave! I'd heard of him but had to look him up as I'm only a spring chicken of 43. I used to own a GMC Jimmy though, as it happens. Hence the Typhoon in the garage. When I was a lad I met him once, he was an awkward little feller of the opposite nature to his stage character, a very odd bloke? I just Google'd "Jimmy Cliotheaero" and it goes straight to him and links it back to here, chicken or egg? https://www.google.co.uk/webhp?sourceid=chrome-instant&ie=UTF-8&ion=1#hl=en&output=search&sclient=psy-ab&q=Jimmy%20Cliotheaero&oq=&gs_l=&pbx=1&fp=59c55e3e28a4e30a&ion=1&bav=on.2,or.r_gc.r_pw.r_qf.&biw=1639&bih=783 I hadn't realised Google was a Conundrum Cracker too! Excuse the digression. Edited August 25, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Morpheus Posted August 25, 2012 Share Posted August 25, 2012 http://www.youtube.com/watch?v=IS0EkMbKheE&feature=g-upl The video is a bit short and only gives a couple of seconds of noise but I think if the engine runs and actually drives, I'd inspect the rod bolts before buying another engine. You might have only spun a bearing. What's the oil like and if you cut open the filter and inspect it for debris, you'll get a much better idea if the bearings are all going to be shot or if there's no metal in it, you might get away with re-torquing the rod bolts. To replace the engine with an unknown one could be more trouble than it's worth, even if you do save some money. I know that I wouldn't fit an engine that hadn't been thoroughly inspected first, since there's always a reason why things are removed. If it lacked so much power as to make the previous owner think a TT was the only way to go, there was something wrong with it, since a decent NA will rip the skin off a TT for the first 10 metres due to it's higher compression. Ideally you'd have an NA-T and stay below 9psi. It's as good an excuse to go NA-T as any I can think of, if you can afford it. Just don't drive this engine any more in this condition, or you might throw a rod through the block. That's the next stage if it's a loose rod cap. How thick and black is the oil exactly? This can only be caused by poor maintenance imho. These engines are bullet-proof if looked after. Quite unusual actually, this sort of thing. Quote Link to comment Share on other sites More sharing options...
Morpheus Posted August 25, 2012 Share Posted August 25, 2012 When I was a lad I met him once, he was an awkward little feller of the opposite nature to his stage character, a very odd bloke. Excuse the digression. Yeah, stop going off topic. You'd never catch me doing that. Quote Link to comment Share on other sites More sharing options...
