simbasupra Posted August 23, 2012 Share Posted August 23, 2012 Hi I'm planning on going BPU and was wondering if this could be done in stages? Or should it be done all at once. From what I can make out, as I have a UK spec if I fitted a double decat and new exhaust the boost would only raise to 0.85 bar. To raise the boost to 1.2 I would have to fit a boost controller. Would I need a FCD, new fuel pump, colder grade spark plugs for it only running at 0.85 bar? Or could these items be purchased when I purchase the boost controller and go up top 1.2 bar? Cheers Link to comment Share on other sites More sharing options...
johnny g Posted August 23, 2012 Share Posted August 23, 2012 I think you'll be ok with things at 0.85bar. Above 1bar you'll need a FCD to go with the Boost Controller. The UK fuel pump out flows the Jap one, so you should be ok at 1.2bar - however, it'll be old now, so for £100 I'd get a Walbro. Link to comment Share on other sites More sharing options...
listy Posted August 23, 2012 Share Posted August 23, 2012 With a UK spec, there is no need for a new fuel pump, as the UK spec pump is good for BPU. FCD will be required if you want to up the boost, else you will keep hitting fuel cut. Set to (iirc) 9 if its an HKS one. Colder spark plugs are recommended regardless I guess. A front mount isnt necessary, really a personal preference. A boost controller is required so you can up the boost to that wonderful 1.2 bar. There is no reason why it cant be done in stages. Mine is currently BPU minus fuel pump and FCD, and is 100% fine (except I want more power ) Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 23, 2012 Share Posted August 23, 2012 for £100 I'd get a Walbro. For £115 I got a direct replacement Aeromotive 340 lph fuel pump delivered within 4 days from the States. Arrived yesterday so I haven't had a chance to fit it but prior to purchasing I asked an impartial contact in the motorsport industry for an educated opinion based on make and specs. He rates the brand highly and from a performance stand point he likened it to his own personal choice, the Bosch 044, so I'm expecting good things from it. If it lasts longer than a day it'll have the Walbro I fitted last time trumped anyway! Link to comment Share on other sites More sharing options...
simbasupra Posted August 23, 2012 Author Share Posted August 23, 2012 Would a walbro be better than a new uk spec pump? Link to comment Share on other sites More sharing options...
johnny g Posted August 23, 2012 Share Posted August 23, 2012 I'd get a new UK pump. Link to comment Share on other sites More sharing options...
Nic Posted August 23, 2012 Share Posted August 23, 2012 Would a walbro be better than a new uk spec pump? No the UK pump flows more than the 255 Walbro, they are also very quiet unlike the Walbro. Link to comment Share on other sites More sharing options...
Suprab1 Posted August 23, 2012 Share Posted August 23, 2012 Is the uk pump plug & play with a jspec? What's the part number for one & how much roughly for a uk spec pump? Link to comment Share on other sites More sharing options...
Nic Posted August 23, 2012 Share Posted August 23, 2012 Is the uk pump plug & play with a jspec? What's the part number for one & how much roughly for a uk spec pump? No it doesn't fit in the j-spec hanger, it can be bodged to fit with a jubilee clip, but would be better with a UK fuel pump hanger. Link to comment Share on other sites More sharing options...
Suprab1 Posted August 23, 2012 Share Posted August 23, 2012 No it doesn't fit in the j-spec hanger, it can be bodged to fit with a jubilee clip, but would be better with a UK fuel pump hanger. Cool, by any chance do you know what they flow? Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 23, 2012 Share Posted August 23, 2012 (edited) In all honesty BPU is so cheap to do get it in 1 go mate. You will be more satisfied with BPU feeling that extra power rather than builing it up slowly. You can do decent BPU set up for about £1k. I think its only financially wise to build up a single turbo set up bit by bit as its mega money.. Paul offers a great BPU kit to make it easier http://whifbitzperformancetuning.co.uk/toyota-supra-performance-packs-garage-whifbitz-p-11430.html Regarding fuel pump I found my Walbro 255 most satisfactory and now I'm single I have gone for the 450 which is damn quiet.. Edited August 23, 2012 by a98pmalcolm (see edit history) Link to comment Share on other sites More sharing options...
simbasupra Posted August 24, 2012 Author Share Posted August 24, 2012 In all honesty BPU is so cheap to do get it in 1 go mate. You will be more satisfied with BPU feeling that extra power rather than builing it up slowly. You can do decent BPU set up for about £1k. I think its only financially wise to build up a single turbo set up bit by bit as its mega money.. Paul offers a great BPU kit to make it easier http://whifbitzperformancetuning.co.uk/toyota-supra-performance-packs-garage-whifbitz-p-11430.html Regarding fuel pump I found my Walbro 255 most satisfactory and now I'm single I have gone for the 450 which is damn quiet.. i would do it in one but the exhaust and decats im looking at are over 1k on there own. then all the other bpu stuff on top. Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 24, 2012 Share Posted August 24, 2012 (edited) Don't forget to keep an eye on the sales section for used parts. I went BPU on the 1JZ for a damn sight less than a thousand pounds. The only new parts I bought were a restrictor ring and some gaskets from Chris Wilson and a wideband AFR meter from ebay. Edited August 24, 2012 by pedrosixfour (see edit history) Link to comment Share on other sites More sharing options...
johnny g Posted August 24, 2012 Share Posted August 24, 2012 I've got an exhaust and midpipe up for sale Link to comment Share on other sites More sharing options...
Samurai 20V Posted August 24, 2012 Share Posted August 24, 2012 No the UK pump flows more than the 255 Walbro, they are also very quiet unlike the Walbro. What do you mean Nic? I don't hear anything from my Walboro unless I am not listening for the right noise? Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 24, 2012 Share Posted August 24, 2012 What do you mean Nic? I don't hear anything from my Walboro unless I am not listening for the right noise? Walbro 255 is known for being noisey little pump compared to stock and some other aftermarket units. I could hear mine whirring away no problem. Link to comment Share on other sites More sharing options...
Samurai 20V Posted August 24, 2012 Share Posted August 24, 2012 Walbro 255 is known for being noisey little pump compared to stock and some other aftermarket units. I could hear mine whirring away no problem. Strange, I don't hear anything from mine.. Supplied by Chris Wilson, so I know its the real deal.. Link to comment Share on other sites More sharing options...
Suprab1 Posted August 24, 2012 Share Posted August 24, 2012 I had a walbro 255 in the evo & heard it inside & outside the car but then the supra is much better built & more sound proof. Link to comment Share on other sites More sharing options...
sideexitsupra Posted August 24, 2012 Share Posted August 24, 2012 Can't hear mine either. Link to comment Share on other sites More sharing options...
rallly Posted August 26, 2012 Share Posted August 26, 2012 For £115 I got a direct replacement Aeromotive 340 lph fuel pump delivered within 4 days from the States. Arrived yesterday so I haven't had a chance to fit it but prior to purchasing I asked an impartial contact in the motorsport industry for an educated opinion based on make and specs. He rates the brand highly and from a performance stand point he likened it to his own personal choice, the Bosch 044, so I'm expecting good things from it. If it lasts longer than a day it'll have the Walbro I fitted last time trumped anyway! Do you have a link to the aeromotive fuel pump? Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 27, 2012 Share Posted August 27, 2012 Do you have a link to the aeromotive fuel pump? http://www.ebay.com/itm/110867548351?_trksid=p3984.m1439.l2649&item=110867548351&cmd=ViewItem&sspagename=STRK:MEWNX:IT&vxp=mtr Link to comment Share on other sites More sharing options...
rallly Posted September 9, 2012 Share Posted September 9, 2012 When through bpu upgrades do you add the colder plugs? Link to comment Share on other sites More sharing options...
rallly Posted September 9, 2012 Share Posted September 9, 2012 No it doesn't fit in the j-spec hanger, it can be bodged to fit with a jubilee clip, but would be better with a UK fuel pump hanger. Will a UK spec hanger fit the j-spec ? Link to comment Share on other sites More sharing options...
Nic Posted September 9, 2012 Share Posted September 9, 2012 When through bpu upgrades do you add the colder plugs? Above 1bar you'll need cooler grade plugs. Not tried it but the US/UK hanger should fit I think. Link to comment Share on other sites More sharing options...
