ashbuster Posted August 23, 2012 Share Posted August 23, 2012 looks like my project is over for now. just noticed my crank pulley has a wobble Link to comment Share on other sites More sharing options...
welshbuddy Posted August 23, 2012 Share Posted August 23, 2012 How bad is it wobbling? Check the bolt? + how tight it is on scale. Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 its wobbling pretty bad tried to get a video but like a idiot i didnt save it lol Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 just checked and it seems solid but somethings not right, its like its tilted slightly or the part in the middle has moved heres some photos look at the first pik it will explain what im seeing as its hard to explain then look at these which show it better Link to comment Share on other sites More sharing options...
RobD Posted August 23, 2012 Share Posted August 23, 2012 Do the tip ex test, aux belt needs changing also! Link to comment Share on other sites More sharing options...
Swampy442 Posted August 23, 2012 Share Posted August 23, 2012 Ill bet if you took the aux belt off the pulley will just seperate in your hands. Link to comment Share on other sites More sharing options...
mellonman Posted August 23, 2012 Share Posted August 23, 2012 Ill bet if you took the aux belt off the pulley will just seperate in your hands. yes that you need a new crank pulley my friend Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 so it could just be the pulley and not the crank? Link to comment Share on other sites More sharing options...
mwilkinson Posted August 23, 2012 Share Posted August 23, 2012 That looks like it has delaminated. The outer ring is off centre compared to the inner part. That's a new pulley for you sir. Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 (edited) not as bad as i first thought, new aux belt which i knew i needed anyway and new pulley , i was expecting new engine :O maybe not that bad but even so this bolt is going to be a bitch any ideas how much they are roughly ? Edited August 23, 2012 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
dan294 Posted August 23, 2012 Share Posted August 23, 2012 £282 off whifbitz. Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 .. Link to comment Share on other sites More sharing options...
listy Posted August 23, 2012 Share Posted August 23, 2012 £282 off whifbitz. Thats gone up in the last few weeks then No more than 4 weeks ago I paid £238 delivered iirc. Or is that for the Titan one? Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 shocking how something like that is so expensive or are these not stock? Link to comment Share on other sites More sharing options...
dan294 Posted August 23, 2012 Share Posted August 23, 2012 http://whifbitzperformancetuning.co.uk/toyota-supra-engine-components-toyota-parts-toyota-p-11669.html Looks like a standard one. I got a quote from a Toyota dealer that I use for £295 all in, including a 15% discount last week! Link to comment Share on other sites More sharing options...
listy Posted August 23, 2012 Share Posted August 23, 2012 The one I got is an OEM copy. Been 100% fine so far and was assured by Paul it is as good if not better than the OEM one. However, if going for big power in the future, may as well fork out for the Titan one. Link to comment Share on other sites More sharing options...
listy Posted August 23, 2012 Share Posted August 23, 2012 Here you go Ash. Stock and uprated pulley links. Stock Crank Pulley ATI Crank Pulley Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 thanks guys really stupid question im going to ask now im not sure how long this has been doing this for because it doesnt make a sound and it feels rock solid but you can see its nakered, only wobbles on idle with revs it straightens what are the odds of me being able to drive 10 mile without it flying off? or can this go at any second now? Link to comment Share on other sites More sharing options...
dan294 Posted August 23, 2012 Share Posted August 23, 2012 Looks like the cheaper one is a pattern part. The £282 one is a genuine Toyota. You could drive it, but it may not be worth the risk! Link to comment Share on other sites More sharing options...
listy Posted August 23, 2012 Share Posted August 23, 2012 I wouldnt drive it too far mate. Off boost you *might* be ok. Mine was like this, and after I put a load of bits back together, gave it a couple of revs to make sure everything was back how it should be, and it fell off! If that was on a main road, I probably would have lost my rad at the same time. Get a pulley delivered next day, and replace it yourself. Took me 45 minutes Link to comment Share on other sites More sharing options...
ashbuster Posted August 23, 2012 Author Share Posted August 23, 2012 how did you do it so quick? dont everyone struggle with the bolt Link to comment Share on other sites More sharing options...
listy Posted August 23, 2012 Share Posted August 23, 2012 I used the starter motor mate. Breaker bar on the bolt, resting on the floor PASSENGER SIDE (cant emphasize this enough, else you would do a lot of damage!), dont start the car, but crank it over, and the bolt will come off. Probably helped that I had mine off a few weeks earlier to do the oil pump etc. Then its a case of removing the pulley (easier said than done, I had a very large Fijian pull it off lol) New pulley on, bolt back on, (torque it on, cant remember off the top of my head what it needs to be, I *think* 230 nm *i think*) Belt back on, ensure all the timing is lined up correctly, and away you go Link to comment Share on other sites More sharing options...
Oddball87 Posted August 23, 2012 Share Posted August 23, 2012 Yup new pulley mate. When we do the single conversion i can change it all then, might as well do the cam belt at the same time bud Link to comment Share on other sites More sharing options...
Oddball87 Posted August 23, 2012 Share Posted August 23, 2012 Give Daz a txt he always finds cheap OEM parts somehow lol Link to comment Share on other sites More sharing options...
Swampy442 Posted August 23, 2012 Share Posted August 23, 2012 Not expensive really, but it is a service item and it does have a given life span. Buy a new one, fit it, forget about it. I have a genuine Toyota crank pulley tool, saves all the danger of long bars and turning engines over. Link to comment Share on other sites More sharing options...
