Torque convertor
mclarenross
The part numbers are different:
1JZGTE = 32000-22170 vs 2JZ-GE = 32000-30270 so they are unlikely to be exactly the same, especially as 1JZGTE is 280hp and 2JZGE is 225hp. However the torque converter bolts are the same, so they may bolt up.
The part numbers say no, but I wager you a beer you wouldn't be able to find a difference between them.
I have an N/A torque converter you can have for the cost of P&P.
If you prove me wrong, I will refund the postage.
Or maybe NeilTT has a Soarer 1JZ-GTE torque converter you could have?
Further to my previous post.
Bell housings.
2JZ-GE has J1
1JZ-GTE has J2?
2JZ-GTE has J3
The J3 is 20mm deeper than J1 to accommodate thicker torque converter.
I will measure the depth of the J1 and J3 later today and you can measure the depth of your J2.
Maybe you have just won a pint off me and found a t.c. from Neil?
If it's not broken don't fix it, unless abused a torque converter can live longer than you.
Re. post 5 & 8.
Today I have taken some pics and measurements of 2JZA80-GE and GTE components.
These pics and measurements will allow you to find the answer your original question.
Bell-housing
J1 2JZA80-GE 120mm
J1 1JZA80-GTE 120mm
J3 2JZA80-GTE 140mm
Left- 2JZA80-GE right 2JZA80-GTE
Torque-converter
2JZA80-GE 102mm
1JZA80-GTE must surely be 102mm
2JZA80-GTE 117mm
