SWAP N/A to VVT-i Twin....engine indicator in dashboard ON!
RastaMc
HI guys....
I've made a swap from my N/A to a VVT-i twin turbo J-spec. Awesome the power and how fast the car goes. Also the sound with a 3" pipe Blitz Nur Spec R is fabulous.
But I've a trouble....
When I accelerate the car, parking as well as driving, the engine logo/symbol (lamp) on the dashboard turns ON. The car doesn't manifest any problem at all, but I don't know what can be wrong with the motor, ECU or something else.
Does someone has experience with this?
And I've a question...
On the suction pipe after the air filter, there is the MAP sensor situated. Can you eliminate this ITEM? Or locate it somewhere else? The point is that it doesn't has the same diameter of the suction pipe and I don't know how to locate it.
Cheers
Thanks guys for the information.
Seeing that my car doesn't have neither TC nor ABS I think this is probably the issue. I'll find out how to fix this with the mechanic.
If anyone know how to fix it, please....
If I fix it I'll share "how to do this" in this thread.
  • 2 weeks later...
