Brazil Posted August 22, 2012 Share Posted August 22, 2012 Gents, Can anybody tell me what would be required to convert a VVTI Head to a None VVTI? Can it be a simple swap? The none VVTI head would be used on my single turbo conversion with power goal of 700bhp. Quote Link to comment Share on other sites More sharing options...
johnny g Posted August 22, 2012 Share Posted August 22, 2012 You might want to hold out a couple of days ... Quote Link to comment Share on other sites More sharing options...
Wez Posted August 22, 2012 Share Posted August 22, 2012 Why would you get rid of VVTi? Quote Link to comment Share on other sites More sharing options...
Brazil Posted August 22, 2012 Author Share Posted August 22, 2012 (edited) Because of the restrictions Chris explains below; Another reason is that I am intending to buy a already built head so why not buy the best performance one. Originally Posted by Chris Wilson I wouldn't use a VVTi head at all. it's not true twin cam control like VANOS, and the choice of cam profiles is extremely limited. Plus I am not convinced the VVTi actuator is up to controlling cams with aggressive ramp angles, hence the odd rattling from the thing when more "racy" profiles are used. I'd stick with a properly prepped used none VVTi head, (new guides, and check the bucket to head clearance on used heads) or a new casting. If you are on a budget I would most definitely not use a VVTi head, as there's a lot more mapping time with doing a full VVTi map under lots of load sites. Keep it simple, but do the simple stuff PROPERLY. I've not made up my mind I am simply exploring my options. Edited August 22, 2012 by Brazil (see edit history) Quote Link to comment Share on other sites More sharing options...
