Jonnybravo2667 Posted August 21, 2012 Share Posted August 21, 2012 Hi everyone, does anyone know how much i going to have to pay for a rear wheel bearing to be fitted? I have a new wheel bearing with seals and clip Thanks for any replies Link to comment Share on other sites More sharing options...
sideexitsupra Posted August 21, 2012 Share Posted August 21, 2012 Not sure on how much, but you need to check the bearing flange too. These are very expensive, about £200 if I remember correctly. I recently had a rear bearing go on the way to Suprapod :-( , and I got a complete hub assembly from Keron. Far cheaper, but I guess I don't know how long it will last. Link to comment Share on other sites More sharing options...
Guest aspire Posted August 21, 2012 Share Posted August 21, 2012 i looked into having this done also, i was quoted £240 inclusive to replace both rear bearings, that is on the basis i supplied parts, but i am very concerned with how fragile the hubs are when trying to press the old bearings out, or that is what i have been told to the OP, have you tried nipping yours up? Link to comment Share on other sites More sharing options...
Jonnybravo2667 Posted August 21, 2012 Author Share Posted August 21, 2012 done that already but to no avail lol, want to get it done asap for peace of mind Link to comment Share on other sites More sharing options...
Jos Posted August 21, 2012 Share Posted August 21, 2012 i looked into having this done also, i was quoted £240 inclusive to replace both rear bearings, that is on the basis i supplied parts, but i am very concerned with how fragile the hubs are when trying to press the old bearings out, or that is what i have been told to the OP, have you tried nipping yours up? The hubs are not that fragile, I pressed the bearings out with a 10 ton press, no problem. Getting the hubs of the car is the hardest part. Link to comment Share on other sites More sharing options...
Digsy Posted August 21, 2012 Share Posted August 21, 2012 I went the 2nd hand hub route and gave it to a local garage to do after wasting an entire Easter weekend trying to get the upright off myself. I think I got charged a coupld of hundred pounds for labour, and the garage told me that the job broke their hydraulic ball joint splitter. Link to comment Share on other sites More sharing options...
Batmax Posted August 22, 2012 Share Posted August 22, 2012 Do any of you have buy DORMAN 930-415 Hub for supra ? Link to comment Share on other sites More sharing options...
linconhawk Posted August 22, 2012 Share Posted August 22, 2012 I had one fitted to the rear a few months ago. Pattern part, inc fitting was around £200. Hope that helps Link to comment Share on other sites More sharing options...
Batmax Posted August 22, 2012 Share Posted August 22, 2012 My question is did you notice any downgraded or is the same as oem ? any noise ? Link to comment Share on other sites More sharing options...
linconhawk Posted August 22, 2012 Share Posted August 22, 2012 It's perfect IMO, cant tell the difference atal... Link to comment Share on other sites More sharing options...
Batmax Posted August 22, 2012 Share Posted August 22, 2012 Thanks Link to comment Share on other sites More sharing options...
Batmax Posted August 24, 2012 Share Posted August 24, 2012 But doesn't exit for the rear ? Link to comment Share on other sites More sharing options...
