Recaro Questions
SupraP-Z
1). What is the difference between the stock recaro's and other aftermarket ones? (apart from appearance)
2). Can the stock recaros be bolted straight on (with the right rails) using existing fittings?
3). If changing from stock cloth seats to oem recaros, will all electrical functions still be intact? seat adjustment etc
Im sure there are more questions, i just cant think of them right now. Just thinking what i would need to fit recaros into the supe, my seats are j-spec pre-facelift
1.As to differences,most people use Bride subframes when fitting Recaros but AFAIK the fittings are the same
2.Dont think the fittings from your existing seats will fit, but if you get the OE Recaros with frames and mounts then yes
3.I dont think Recaros have any electrics and adjustments are all manual.
