Laquer not gloss finish??
Noz
Tinting some rear lights, the tint came up nice with a shine but it's not the best, so gave them a coat of laquer which looks gorgous until it goes off, with which a matt finish is left? Any ideas? Is it drying to fast maybe due to heat?
I did a lot of rattle can spraying over the weekend - including laquer. I found the results to be massively variable. The best results I got were from holding the can quite close (about 7" away) and keeping everything moving but at the same time ensuring that I put a decent coat on. Worst results were on an area where I was paranoid about getting a run, so I (ironically) followed the instructions and built up thin coats holding the can about 12" away. The former gave a thick-looking glossy finish after two coats, whereas the latter had a very matt look and much rougher feel to it.
Both of these were over paint, so I was putting the first coat of laquer on while the base coat was still very slightly tacky. I guess putting it on polished plastic would make it very prone to running if you didn't use the "thin layers" technique.
If you cant get clear coat lacquer to shine out of the gun, your spraying or mixing it wrong.
I used clear coat laquer that I've clear coated other items with no problem.
I gave both coats a heavy spraying around 7" distance until I had a nice glossy finish, it jus wont set right. I dont want to try to polish it, it wont take right after that so maybe i need to try something new. my shed does get like an oven though, could this affect the drying process?
If its quite a rough finish, sand it down lightly with 2000 grit, then buff it with Farecla G3 to restore the shine (tis what bodyshops use), thats what i did on mine. Laquer in rattle cans is a nightmare, it just never comes out perfect. On my taillights i had to sand it down and then spray over it again, also came out quite good. The thin layers like you said came out really dull and dusty looking, not glossy looking at all
is the laquer leaving a milky finish ??? Or just dull all over. Could be the tinting spray reacting with the laquer and dulling it down. Try the G3 on it....if that doesnt work but you have enough spray left, try another tint, then leave it a good day or two and then try the laquer over the top of it. Infact might be best to get a rear lense from something random from a breakers and test out the sprays etc on it all before doing it on your own lights.
There is a slight dull look to it for sure. Not sure about a milky look, I did leave it for a day before I laquered them. I was only doing these for a favour I don't want to have to spend hours polishing them when I was trying to help someone out.
I specifically waitied for a baking hot day to do mine and it didn't seem to cause any issues. I have heard that high humidity can make laquer go milky, though.
I also kept the cans in my airing cupboard when they were not being used (even just betwen coats), and shook them for at least two minutes before use.
Edited by Digsy (see edit history)
Is that what you're doing in your avatar? :think:
Problem sorted.
Think there was a reaction on the top layer. Bought another can of laquer, a good polish didn't help so cooked each layer properly and just kept giving it another coat until it went glossy. Alot of work every morning and evening just for bloody tinted lights, cost me a whole can of laquer just to sort this argh! Worth it though they look nice. Lucky customer!
